grinding noise!?!?
Old Sep 18, 2005 | 11:17 PM
ozmaster's Avatar
grinding noise!?!?
Ok, so I've been having a problem for a while now. Whenever I drive I hear like a grinding noise and when I brake, it sounds even worse. Do you think it could be my brake pads?? I will be jacking the car up and taking a look tomorrow. Is there anythign else it could be besides the brakes and anything else I should look for when I have it jacked up? Any help appreciated.
Old Sep 18, 2005 | 11:30 PM
akasirlancerlot's Avatar
might be ur pads they might need to be replaced.
Old Sep 19, 2005 | 07:10 PM
Supa tek's Avatar
Your pads are most likely metal to metal with the rotor. You probably have between 35-45,000 miles and thats when they need to be replaced. By the sound of it your going to need new rotors too. Take your front tires off and feel the inside of the rotor and feel if theres any harshness to the roto suface. If there is, start ordering.
Old Sep 19, 2005 | 11:18 PM
ozmaster's Avatar
yeah..I have around 47,000. I didn't know I might need rotors too. I'll check them out. I have to wait till friday to get a look. THanks a lot supa tek.
Old Sep 20, 2005 | 06:16 AM
datdjrobp's Avatar
sadly, you probably wouldn't have "needed" new rotors if the pads had been changed.
Old Sep 20, 2005 | 01:17 PM
dhonda's Avatar
If the mechanic determines that you don'tneed new pads/rotors there is a special gel that they can coat the pads with that reduces certain vibrations. These vibrations often will be the cause of the "squeaking".
Old Sep 20, 2005 | 02:07 PM
grubiaco's Avatar
On the positive side it gives him the opportunity to get performance pads and rotors.
Also, if they aren't in too bad of shape you can get them turned.
Old Sep 21, 2005 | 01:45 AM
ozmaster's Avatar
yeah right now I have slotted rotors and axxis ultimate brake pads. I just received my package for another set of axxis that I will be installing on friday.
