Headlights Wiring Location?
Old Oct 29, 2005 | 10:36 AM
StreetSleeper8's Avatar
Wiring Location?
I m trying to find the positive wire that makes my headlights go on and off? So i can hook it up to my halo gauges.
Mike
Old Oct 29, 2005 | 11:45 AM
akasirlancerlot's Avatar
plz search.. look for the cedia headlight discussion and find ur wire instaed of making the thread.
Old Oct 29, 2005 | 06:16 PM
i have looked, trust me.
I m not lookign for the wiring that goes to the headlights. I m talking about the wire that comes out of the light switch right next to the steering wheel that turns it on and off. I need to find the + wire so I can tap it.
Mike
Old Oct 29, 2005 | 06:44 PM
u want them to turn on when u turn on ur normal lights? or ur brights or ur turn? which one. y not just tap it at the light?
Old Oct 29, 2005 | 06:49 PM
psmokie68's Avatar
Mike
look for the wire that turns on your parking lights instead of your headlights
Old Oct 29, 2005 | 08:44 PM
at least can someone pinpoint where is the wire that comes out of the left black stick by the steering wheel that turns on/off headlights and turn signals, etc.
Mike
Old Oct 30, 2005 | 06:42 PM
bump
Old Oct 30, 2005 | 08:39 PM
BigP436's Avatar
http://www.twardnw.com/uploads/lancer_wire_diag.pdf
should be in there somewhere
Old Oct 30, 2005 | 08:43 PM
twardnw's Avatar
haha, oh yeah, that's on my server
according to the diagram, the only thing the switch on the steering column does is supply enough power to the front ecu (basically a bunch of relays in one assembly) and then a relay provides the power to the headlights
page 90-58 in that PDF BigP linked to
Old Oct 30, 2005 | 09:21 PM
yikes! let me try find where it is. A simple pinpoint to what color and location of the wire would just simplify the whole thread.
Mike
Old Oct 30, 2005 | 09:22 PM
i cant even understand what its talking about.
Old Oct 31, 2005 | 07:26 PM
Z Lancer Man, maybe you do know where? help me out
Old Oct 31, 2005 | 11:39 PM
twardnw's Avatar
ok, here's the jist of it. You don't want to power anything off the wire which comes out of the steering column. The circuit is only going to be enough to power the headlight relay in the front ecu. The place to tap into would be pin 6 (for low beams) or pin 2 (for high beams) on the front ecu
looking further into the diagram, it would appear that there is an ecu of sorts for just that switch
and if you wanted it for the parking lights, it is pin 8 on the front ecu
and wow, as I study this more.... The switches are not even controlling the relays, they are actually powering transistors, which in turn are powering the relays, so tapping into the switch side of any of these circuits would not be too good of an idea
Old Nov 4, 2005 | 09:40 PM
bump, REALLY NEED help on WHICH wire to hook up with?! a simple detailed step by step or a picture or a very clear diagram would help a lot!
mike
Old Nov 4, 2005 | 09:51 PM
Z_Lancer_Man's Avatar
I'm on it
c900t16
Dec 24, 2020 05:13 PM
BlueEvoEx
Feb 2, 2015 06:48 PM
dizzle06ix
Mar 27, 2013 08:49 PM
RA032924
04-06 Lancer Ralliart How To Requests / Questions / Tips
Feb 16, 2009 09:51 PM
kmcconn9
Aug 20, 2007 12:06 PM
