Repair Headlight from accident?
Old Nov 15, 2005 | 09:42 AM
timdog4life's Avatar
Ok, so last night I got into an accident with a deer on the highway coming home.
The damage includes:
-dented hood
-scrapped front bumper
-broken cedia headlight (mounting tabs)
-completely destroyed driver side fender
-dented driver side door that wont open.
Now, most of the above mentioned damage it stuff I'm not worked up about because insurance will cover it. But I'm kinda at a loss when it comes to the headlight. I know the bodyshop will just replace it with a factory headlight.
Is there anyway to fix the plastic mounting tabs on the headlight? They both snapped right off from the light.
Is there any kind of glue, or a process of melting the plastic and then remelting it together to fix it? I really dont want to shell out another $300 or whatever the hell they're selling for these days just to replace one headlight. There's no actual damage to the light other than the mounting tabs....
Anyone think it can be fixed?
Old Nov 15, 2005 | 10:33 AM
akasirlancerlot's Avatar
glue the tabs man! use some hot glue, hell u can even use some small metal brakcets and screw them in.
Old Nov 15, 2005 | 10:36 AM
both sound like good ideas.... I'll have to try that
Thanks for the suggestion.
Old Nov 17, 2005 | 12:48 AM
Tweak3D's Avatar
scuff and clean both sides of the braket where it broke and liberaly use JB-Weld, won't get soft like hot glue or anything and will hold up quite well in there.
-Justin
Old Nov 17, 2005 | 03:46 AM
RobertK's Avatar
yeah your not the only one.
I'm still looking for a cheap fender.
Old Nov 17, 2005 | 04:40 AM
travelsize420's Avatar
Most Recent Mods:
hitting a deer @ 70mph hahahha
my pass. side headlight's mounting bracket is so broken too. its not that off-level, but it is slighty tilted up. i want some cedias.
dont you ****ing love all the deer here in NJ?
Old Dec 29, 2005 | 02:42 PM
i ended up just buying a new set of cedia lights...and since i've still got my old ones I may be tyring to do something similair to what lookslikeanevo did.
Old Dec 30, 2005 | 08:47 AM
Secret Chimp's Avatar
That was the correct solution. Gluing the tabs on a broken headlight might have worked. But most likely you wouldn't have been able to align them correctly so that they would still be aimable after the fix.
guzmangjr
Dec 11, 2016 09:05 AM
ChicagoEvo9
May 20, 2016 07:18 AM
MisUnderStood
Aug 14, 2015 06:03 AM
Frew
Jul 13, 2014 11:14 PM
bboy_RES
Aug 16, 2010 09:58 PM
