Extreme winter setup?
Old Jan 10, 2006 | 01:44 PM
pgmike's Avatar
I jsut moved from hot florida to blizzardy vail CO. Temps can get well below zero and it blizzards like crap here. How should i setup my car for this change in weather? What oil should i use? Differene in antifreeze from florida? Etc etc, i dont know much about driving in this kind of weather so any hel is appreciated.
I already have a tire thread for help on that: https://www.evolutionm.net/forums/sh...d.php?t=178378
Old Jan 10, 2006 | 01:55 PM
akasirlancerlot's Avatar
drive ur car off a cliff and buy AWD. (only half Joking)
Nice to see you Mike.
Old Jan 10, 2006 | 01:56 PM
ambystom01's Avatar
Get winter anti-freeze (good to -40) and just be sure to plug the car in if it gets below about -15.
Old Jan 10, 2006 | 01:58 PM
pgmike's Avatar
What do you mean plug it in? Thanks for the nfo.
Old Jan 10, 2006 | 02:06 PM
ambystom01's Avatar
Plug the block heater in. If you don't have one, get one.
Old Jan 10, 2006 | 02:11 PM
pgmike's Avatar
Alright, i dont even know where that is located so it looks liek its off to look for my shop manual CD. thx
Old Jan 10, 2006 | 02:16 PM
HobieKopek's Avatar
It was an accessory. You can probably pick it up at the dealership.
Old Jan 10, 2006 | 02:18 PM
pgmike's Avatar
Alright thanks. Should i even be driving in that kind of temps?
Old Jan 10, 2006 | 02:20 PM
HobieKopek's Avatar
Warm up the car. Other than that, if it runs then you can drive.
Old Jan 10, 2006 | 02:21 PM
pgmike's Avatar
Not if it is too bad here. There was a 12day blizzard a week or so ago.
Old Jan 10, 2006 | 02:23 PM
HobieKopek's Avatar
Well, road conditions and temps are two different things though. Temp alone isn't really a reason for problems once you get the car to operating temp.
Old Jan 10, 2006 | 02:26 PM
Walkingchaos's Avatar
def need winter antifreeze and a diff oil, not sure how low you can go with the oil before the oil pump will have issues. and get yourself some decent winter tires, alot of guys suggest blizzaks.
Old Jan 10, 2006 | 02:27 PM
ambystom01's Avatar
You don't need a different oil. I've driven in -40 degree celsius weather with my normal oil in there and its fine. Just let the car warm up first and you should have no problems.
Old Jan 10, 2006 | 02:35 PM
pgmike's Avatar
thanks for the info guys.
Old Jan 10, 2006 | 08:53 PM
03RallyLancer's Avatar
yeah but as you go north... you get a different weight oil... u might want to check into it mike and make sure what you got put in in florida can handle CO winters
