In Cabin Air Filter for '03 OZ Lancer...
Old May 9, 2006 | 08:45 AM
SLVROZ_03's Avatar
Just needed to verify that part # MR398288 (OEM Mitsu Cabin Air Filter) will be needed or will work in my '03 OZ Lancer before I purchase one. I searched and only came up with a '04 Es owner saying it's behind the glove box in his ride. Would it be the same with the '03s?
Thanks
Old May 9, 2006 | 09:09 AM
SLVROZ_03's Avatar
Got 6 hrs before I purchase the filter, anyone know?
Old May 9, 2006 | 09:30 AM
Danno's Avatar
Search in the Evo Forums, there is a lot of information on it there.
Old May 9, 2006 | 09:41 AM
SLVROZ_03's Avatar
As mentioned above, I did search and the only NON-Evo lancer that had any experience with a cabin filter posted that it was located behind the glove box in his '04. My question, does the '03 Lancer OZ have one and is the above part # correct?
Thx
Old May 9, 2006 | 10:00 AM
Danno's Avatar
Yes the OZ has the exact same filter box, I cannot confirm the part number but it will be the same as the evo one.
Edit, found the part number after searching for 3 seconds.
#MN185231
https://www.evolutionm.net/forums/sh...t=cabin+filter
Old May 9, 2006 | 10:07 AM
Redlancer's Avatar
If I'm not wrong, the 02-03 don't have a Cabin Air Filter...
They start to put this only in 04 and later model. I had my control heater unit change under warranty, they put a 04 model on my car because they have a Cabin Air Filter to keep dust away from the mecanism.
Old May 9, 2006 | 10:20 AM
Danno's Avatar
Correct the 03 doesnt have the filter, but the tray is there for it, all you need to do is buy the filter and put it in.
Old May 9, 2006 | 10:27 AM
civilrage's Avatar
s wait we dont have a filter befre the sir blows in the cabin????
Old May 9, 2006 | 11:13 AM
SLVROZ_03's Avatar
Huh, there's a tray to put it in but no filter from the factory in there? Odd...
Old May 9, 2006 | 12:07 PM
Walkingchaos's Avatar
how muc is the filter, hell id add one just to keep crap out of the cabin air vents
Old May 9, 2006 | 02:09 PM
SLVROZ_03's Avatar
I'll let you know in about an hour...
Old May 9, 2006 | 04:34 PM
cableguy5752's Avatar
yes, the 03 lancer has the tray for the cabin air filter, but the manu does not put one in. this is very common with many vehicles. (i used to work at a quick lube and we had to check for cabins) it is behind the glove box and then you have to open the door to where the cabin sits, which proved kinda difficult in my OZ, but i eventually got it open.
Old May 9, 2006 | 07:24 PM
what exactly will that help with ? and can anyone post pictures of the install on an 02-03 ?
Old May 9, 2006 | 07:42 PM
it helps filtrate the air coming into your car from the a/c or heater (the air you breathe) cars that have it already in, you can tell when it needs to be changed or at least looked at when you start getting funky smells through the vents
Old May 10, 2006 | 07:40 AM
SLVROZ_03's Avatar
Missed the auction for it unfortunately. It was only going for $1.99 plus $6 shipping. That one and only bidder got a deal...
