RPMs
Old Aug 17, 2006 | 02:56 PM
Synthrocker's Avatar
RPMs
I know this may be a strange question, but can someone tell me what their RPMs are at 70MPH in 5th and 30MPH in say... 3rd or even second.
I want to see if I put my needle back on in a good spot(I put it on at idle, 500pms) =P
If I remember correctly, at 70mph the RPMs should be 3k/little under 3k?
Old Aug 17, 2006 | 03:25 PM
sykou's Avatar
Hmm. Im guessing you didn't follow this how to?
https://www.evolutionm.net/forums/sh...hlight=needles
Idle should be around 600 with the ac off. For the fuel i say just run your car untill the light comes on and put it just above the E. Temp should be just about the middle when idling at operating temp. Speedo, your not moving then 0 of course. Good luck
Old Aug 17, 2006 | 03:32 PM
I followed it, everything back, I just want to see how off it is if any. And putting the speedo at 0 when stoped doesent work, or dident work for me, it was 10mph off when I set it at 0 found myself one of those radar detector sign things and used that to set my speedo, let my car warm up for the middle on the temp, and filled my gas tank instead of let it go low.
Just wanting to double check with someone who hasent touched theres
Old Aug 17, 2006 | 03:35 PM
sykou's Avatar
10 mph off huh... lol glad to hear everything is back to normal
D-Man
Mitsubishi TC-SST Discussion
May 26, 2020 12:02 PM
tequila357
Feb 18, 2016 11:42 AM
dragon831
Dec 7, 2008 10:14 AM
bigredlancer08
Lancer Engine Tech
10
Feb 27, 2008 03:33 PM
yang123
14
Sep 18, 2007 03:15 PM
