brake problem, need help
Old Sep 17, 2006 | 06:47 PM
02-Lancer-Es's Avatar
my brake pedal recently feels weird, when im in drive or reverse ,not when braking in neutral, the pedal feels like its pumping air rappidly, and u could hear it to, sounds like air pumping , i recently changed my brakes and did a flush , i took out all the air!!!!! and refilled it with dot 4 fluid need help!!!!!!!!!! plz,,,ps my brakes stop great, and dont really have to push them down for them 2 stop
Old Sep 17, 2006 | 06:54 PM
i think the correct term for this is,' Brake Pedal Pulsates)
Old Sep 17, 2006 | 09:02 PM
bump, is anyone goin 2 help me?or i just take it mits and get something dumb like you need an entirely new braking system,lol
Old Sep 17, 2006 | 09:34 PM
OZrallyMatty's Avatar
From: addison, not to be confused with aurora, illinois
u prolly should of used dot 3, dot 4 can corrode the **** in your braking system if its not made for it
Old Sep 17, 2006 | 09:47 PM
but the brake tank says dot 3 or 4, so i hould just flush it and get dot 3 or wat?
Old Sep 18, 2006 | 03:49 PM
Blacksheepdj's Avatar
Natural question - are you SURE you got all the air out of the lines?
Old Sep 18, 2006 | 03:56 PM
yes, my mom pumped the brakes and i closed them,lol,im gona check my lines later, and i f i need to , ill reflush them
Old Sep 18, 2006 | 04:02 PM
Time for SpeedBleeders. Let mom get back in the kitchen...
Might be a good idea just to recheck them. Things can go wrong from time to time. Also, maybe an air buble got sucked in the master cylinder when you were doing it. You never know.
Old Sep 18, 2006 | 05:09 PM
just checked them now, i found out its becuz my engine shakes when the ac is on, and with ac off the brake pedal doesn't do that, im thinking i need to get new spark plugs
Old Sep 18, 2006 | 05:18 PM
Um, no.
You need to not use the A/C. Your engine shakes because the weak little motor has to work harder, and the mushy stock motor mounts allow it to move around.
Now you know.
Old Sep 18, 2006 | 05:27 PM
yep, i need the ac though i live in central texas, its hot and humid, today was high 93 AND low 82
JTCB
Mar 25, 2015 07:40 AM
Talon
11
Feb 24, 2014 05:38 AM
erniebu
Oct 27, 2010 10:19 PM
neodestroyer
Sep 2, 2008 07:20 AM
Orixy
Lancer Troubleshooting
Nov 24, 2006 12:11 PM
