Question
Old Sep 22, 2006 | 11:50 AM
DemisedGabe's Avatar
Originally Posted by Blacksheepdj
Any time you remove a cat, you loose some low-end.
It's simple physics. You can't trick your way around it.
Everytime you remove/change the exhaust, you lower backpressure. So you lose low-end and gain low-end. Any mod to the exhaust takes away from low-end power.
Removing either cat might lead to a CEL. Pulling out the first cat is pretty safe (it's like a cheap header). Removing the 2nd definitely leads to CEL (100%) and won't do as much.
well my testpipe is still on with the o2 sensor spacer from rrm. the light never came on until a few mins. ago.like over 60 miles??is that cus of the testpipe?will it go away?
Old Sep 22, 2006 | 11:58 AM
B-SR's Avatar
I think he means lose low-end and gain high-end.
Try disconnecting your battery again. If you installed it properly then your CEL shouldn't come on.
Old Sep 22, 2006 | 12:00 PM
Blacksheepdj's Avatar
The CEL is from the test pipe and won't go away. (Obviously, check to make sure - auto parts stores will scan you for free nowadays) The RRM CEL fix isn't perfect. It didn't work on my car.
You can look into something more complicated but much more effective --> http://www.mileliminators.com/
Old Sep 22, 2006 | 12:01 PM
Fixed my typo. Sorry.
Lose low-end, gain top-end.
Old Sep 22, 2006 | 12:07 PM
damn that testpipe!!well i am gonna go run a scan, and then put on my stock cat with the cel eliminator, hopefully it goes away.thanks for the help.
