bouncy shifting...
Old Oct 18, 2006 | 04:45 AM
crypto's Avatar
Former Vendor
MOTOR MOUNTS!!!!
is most likely gonna fix the problem. Either fill them yourself with Windo Weld. or buy whole new aftermarket ones. Just for the front and rear.
I did it on my auto cos it was shifting hard, now its super dooper smooth. So smooth infact it made me smile the first time i drove it again.
Old Oct 18, 2006 | 09:52 PM
Blacksheepdj's Avatar
Originally Posted by klexen
I dont try to drive fast or crazy, I just shift how I think I should shift.
Good for you.
NOW try to "shift how the car thinks it should be shifted."
Analogy - if you bang your GF "like a girl should be banged," that doesn't mean she'll enjoy the experience.
Old Oct 19, 2006 | 05:11 AM
crypto's Avatar
Former Vendor
Originally Posted by Blacksheepdj
Good for you.
excellent
Old Oct 19, 2006 | 07:42 AM
Geo_lancer's Avatar
i too at first had prob shifting.. it would be bouncy between first and second gear always.. after a while i became acustomed to the times i shifted smoothly and now the car rides smooth.. no bouncy, bouncy
Old Oct 19, 2006 | 08:08 AM
wickdaddy's Avatar
I am experiencing somthing similar to what you guys are experiencing, but it is not when I am shifting... for example, i'm driving down a 35mph street trying to go the speed limit and be in third gear floating around 2.5rpms. whenever i lightly touch the gas and lightly let go of the gas to try to keep it around the speed limit my car jerks... weird? anyone experienced something like this? (oh and my oz is turboed)
Old Oct 19, 2006 | 10:07 AM
Lox1985's Avatar
I had that but I filled my motor mounts and now its much better. I only did the front motor mount did not have to time to do the rear. But i think as soon as I do the rear mount the problem will go away. Also try not to release the clutch pedal fast, do it smoothly it should not jerk
Old Oct 19, 2006 | 02:38 PM
Car can just be a bit twitchy. My Lancer was the same way (and the RS is REALLY like that). Some Flex motor mounts from Deyeme might not hurt.
Old Oct 19, 2006 | 02:46 PM
Xshieldsx's Avatar
Originally Posted by 72charger
Has anybody had any problems with the RRM steel braided clutch line? Pros, cons???
I got it a long time ago and it is still doing fine. the pedal definitely doesn't feel like stepping in mashed potatoes anymore. The only thing I had trouble with was bleeding and that was just me opening the valve too much. Not bad for $60 or however much RRM is charging for it now.
Old Oct 23, 2006 | 03:27 AM
Foxphyre's Avatar
hmm motor mounts will fix this? hell i just got used to using fine muscle control so smoothly transition from coasting to accelerating and vice versa. how much are these motor moutns and what kind of labor are we talking?
Old Oct 23, 2006 | 03:25 PM
They might help. I wouldn't guarantee that they'll fix it, however.
The mounts are $70 each from Deyeme Racing.
Front one is SUPER simple and can be installed by anyone smarter than a housecat (and if the housecat had opposable thumbs, he probably could too).
Rear one is a dirty c***sucking motherf***er to install. Very tight space, gotta have a lot of patience and small hands. (To give an example, I actually left the rear mount on my Lancer when I sold it!)
If you're smart, you'll just buy the front one and see how you like it. If you decide you HAVE to have more, then buy the rear and spend a day installing it.
If you're having a pro install these, you're probably going to be paying for 3 hours of work for both (just a guess from my installing them). One hour tops on the front one.
Old Oct 23, 2006 | 04:03 PM
Foxphyre's Avatar
so. lets recap:
your saying that the front one is just fine. i understand that you dont guarantee anything for obvious reasons.
the back one is not really needed and is a ***** to install in any case...
ok nowthe final question remains, lets say i have decided that i want the front one. . is it worth the 70bucks? or would you suggest putting that toward something else first
tequila357
Feb 18, 2016 11:42 AM
Lucas English
126
May 25, 2012 04:46 PM
Rumblefish237
16
Sep 1, 2011 02:26 PM
B_boy699
Mitsubishi TC-SST Discussion
Mar 24, 2011 12:34 AM
Evo_Jay
13
Aug 24, 2005 06:07 AM
