Whats the difference?
Old Feb 19, 2007 | 07:27 PM
CHOZEN_Lancer's Avatar
Post Whats the difference?
What are the main differences between the ES OZ and the Ralliart lancers? I know the the ES and OZ are pretty much the same 'xept some suspension on the OZ but im kinda lost about the Ralliart.
Old Feb 19, 2007 | 07:29 PM
mitsuozboi's Avatar
ralliart has completely different engine, suspension, tranny............ makes around 170 hp......... do some research..
Old Feb 19, 2007 | 07:31 PM
ok so its pretty different huh.
Old Feb 19, 2007 | 07:32 PM
ambystom01's Avatar
ES and OZ have a 2.0 l engine making 120 hp and 130 tq. Ralliart has a 2.4 l engine making about 170 hp and 170 tq (as mitsuozboi said). Suspension is very similar as they are interchangeable. Interior is more or less the same save for the seats.
Old Feb 19, 2007 | 08:13 PM
WarTownOZ's Avatar
can you do an engine swap between an OZ and a Ralliart of the same year?
like would it fit up pretty much the same? or is it larger?
Old Feb 19, 2007 | 08:18 PM
ThunderOZ's Avatar
itll cost you but yes it is possible...some custom work is required...
Old Feb 19, 2007 | 08:20 PM
WarTownOZ's Avatar
k thanks. found a wreck RA in the local junk yard, engine looks in great condition just frame damage in the rear.
might be able to get the car for cheap and just swap it then might fix up the ralliart later.
thanks tho.
Old Feb 19, 2007 | 08:22 PM
ThunderOZ's Avatar
here's a link to a swap that happened in the UK https://www.evolutionm.net/forums/sh...=ralliart+swap
and here's a link to a swap in and 04 lancer so it has a evo motor https://www.evolutionm.net/forums/sh...=ralliart+swap
Old Feb 19, 2007 | 08:29 PM
WarTownOZ's Avatar
niice threads.
thanks alot these will def help alot.
