installing pulley myself? que?
How hard is it to install the RRM crank pulley yourself? what special tools would you need if any. I am planning to get it this weekend along with other goodies but i want to try to save cost by installing it myself. I have some mechanical skill but not really confident in doing this. The install cost almost asmuch as the pulley itself!!!! eh, i might just leave it i nto the hands of RRM. help me felllas!
You better have an air-powered impact wrench. I tried to use a borrowed battery-powered impact that was supposed to be good for 200ft/lbs. but it wouldn't budge. I think the battery-powered wrench was overrated. It's a bit of a pain in the neck to get to, but not as bad as the rear engine mount. It's not all that technical to install it's just pulling out a lot of plastic fasteners (that ofter break) in the passenger side wheel well. Then it's just knowing how to remove the belts. I think there's a how to on here for belts. Do a search, it's not a difficult install if you have a strong enough wrench and know how to get the belts off.
When myself and a friend installed one of these on his OZ, we ran into the same issues. A 200 ft/lb impact wrench won't cut it. You really need a pneumatic one that can do 600 ft/lbs. We were able to get it off with a really large breaker bar and leaving the car in first with the foot on the brake, but that's more stressful on the bolt and I wouldn't recommend it.
