question bout tail-light set up.
Old Apr 22, 2007 | 01:58 PM
icemanchanx's Avatar
hey guys i purchased a pair of Ralliart taillights from another member for my ES and i installed them today. They look fantastic, but i was wondering how is the trunk sealed w/ the lights? i noticed there wasn't any rubber moldings round the taillights. so when it rains does the water just go around the lights or something?
And i also noticed that my right tail light doesn't line up w/ the body and sticks out about about 1 or 2 mm (very minimal) past the body on the side. Do u guys think i will have a problem w/ leaks? or will it not be a problem? The part of the light thats along the backside of the car lines up fine.
Old Apr 22, 2007 | 02:05 PM
drucea's Avatar
You should be fine. They fit just like the ones that came on your car so leaks won't be a problem. Some peoples tail lights do stick out a tiny bt like you said ok the side. Not sure why, but I haven't seen any problems with it. I'd say either pour some water on it or wash the car and check for leaks. If nothing, then you are good to go.
