rrm testpipe?
Old May 15, 2007 | 10:29 PM
tom-oz rally's Avatar
rrm testpipe?
is it true u can't use the test pipe on high ways, well i wanted to know if anyone uses it and if it does anythgin and is it worth getting or no?
Old May 15, 2007 | 10:38 PM
kungfugirl's Avatar
1. Search
2. Search
3. Because i will likely get semi-flamed for telling you to search. heres your answer to the best of my ability.
- what are your mods?
- It will free up 1-2 hp Naturally aspirated.
- I assume you mean "street use" and if so it is a hefty fine for getting pulled over in most states.
IMHO spend a lil more, and get a high flow cat. Please learn to take time and type out your responses in full sentences.
Thanks.
Old May 16, 2007 | 03:39 PM
lancerman360's Avatar
makes your car like 389845450 times louder and you gain about 1hp.
Old May 16, 2007 | 03:46 PM
mitsuozboi's Avatar
yes. it is "illegal" because you are eliminating the cat. Like was said. Your exhaust will be super loud. smell a bit worse and lose low end torque. Its good if your tracking your car. bad if your not. save your money.
Old May 16, 2007 | 04:02 PM
Kurt's Avatar
Search. This is a well covered subject.
Closed.
