DIY SRI - what to make a bracket from?
Old Apr 18, 2008 | 05:40 PM
4no's Avatar
4no
I just bought a K&N cone filter and a maf adapter from ebay. I cleaned the throttle body and installed the intake
It sounds great but it kinda wiggles around in the engine bay and knocks into the master cylinder... i can hear it in the cabin in first gear... What should i secure it with?
Post pics if you have any! I want a clean way to mount it. Thankss
Old Apr 18, 2008 | 06:18 PM
Blacksheepdj's Avatar
Anything. Hell, I've just used zip-ties to hold intakes in place in the past.
Old Apr 18, 2008 | 06:26 PM
4no's Avatar
4no
lool i want a solution which looks decent i hate that knocking sound i'm hearing right now. i'll see what i can come up with tomorrow....it's getting dark out...
Old Apr 18, 2008 | 07:01 PM
Try the parts stores. They usually have DIY parts, so they might have a metal bracket you can use. Often, you can just bend it to fit your needs.
Old Apr 19, 2008 | 03:08 PM
Newrage1's Avatar
Home made bracket yo!
they sell different sized brackets at Home Depots.
Stick one on the pipe, and pin it up somewhere.
Old Apr 19, 2008 | 03:59 PM
atilla's Avatar
you can make your own brace with some aluminum. bolt it to the MAF adapter and there's actually a little spot from where the stock airbox was attached that is a perfect place to throw the bolt to anchor the whole thing to.
Old Apr 19, 2008 | 05:25 PM
4no's Avatar
4no
yea i got it mounted too lazy to go out and take a pic right now but it's a bracket that mounts to a ground bolt near the strut tower and attaches to my maf adapter.... i love the sound of my sri !
I stupidly forgot to attach my maf plug after i put the bracket on leaving me with a check engine light..... really freaked me out cause i just did my timing belt/ water pump and drive belts....i thought i screwed up something with the timing belt
I disconnected the batttery for about 20 mins to clear the code.....gotta reset my radio stations now =(
Old Apr 19, 2008 | 05:31 PM
ES_02's Avatar
hah i should post some pics of my setup.... i got a long piece of metal bracket thing and bent it so it supports the intake and moves around a bit and such.... its real nice...
Old Apr 19, 2008 | 05:46 PM
sgand's Avatar
Wait, I forget how mine is mounted. I think it's zip tied?
