Remove de-badging clear coat leftovers?
Old Jul 11, 2008 | 09:38 AM
toolmanblink182's Avatar
I recently debadged my car, and I am wondering how I would remove this:
I have tried wet sanding with 1500 grit, but to no avail. I even tried rubbing compound, but that makes it stand out worse! Please help!
Old Jul 11, 2008 | 10:40 AM
Stuntfly02's Avatar
Try getting some petroleum distillate(its an adhesive solvent) and try rubbing it off. Be careful because too much and it can remove the clear coat and paint. That is most likely dirt on the adhesive that is left over. Or you are one of the unlucky few that dirt and possibly wax has built up and created a permanent outline.
Old Jul 11, 2008 | 12:35 PM
I think its a permanent thing, but I will try the petroleum distillate. Thanks!
rav's Avatar
rav
I used a little goo-gone and it came off.
Old Jul 11, 2008 | 12:48 PM
Unfortunetly, not even the famous Goo-Gone worked...
Old Jul 11, 2008 | 12:57 PM
UT_Evo's Avatar
If it is just adhesive stuff, try peanut butter. Leave it on for like an hour, and then go out and wash it off. If it is worse than the adhesive stuff (etched in the paint) good luck.
Old Jul 11, 2008 | 01:29 PM
PSI NRG's Avatar
Clay bar
Old Jul 11, 2008 | 01:54 PM
forty9's Avatar
i was one of the unlucky few, that had a permanent shadow where the badges used to be. and nothing worked, so finally bought some new badges and put em on. dont like the look but was my only choice it seemed.
Old Jul 11, 2008 | 02:53 PM
WangMan's Avatar
I tried a clay bar, goo gone, gasoline... nothing would get the shadow off mine and it's all the way across my trunk: LANCER
If anything works for you, please let me know lol
Old Jul 11, 2008 | 03:52 PM
rav's Avatar
rav
scratch remover gels? lol i duno..
or maybe touch up paint as a last option :/
Old Jul 11, 2008 | 05:10 PM
It is not the goo left over, it is etched into my clear coat. 1500 grit sand paper and rubbing compound dont work. Anything else?
Old Jul 11, 2008 | 06:55 PM
Hellacious's Avatar
leave it be and pass it off as ghost badges
Old Jul 11, 2008 | 07:02 PM
bcollinstex's Avatar
Do you have a high speed buffer? Get some polishing compound and put some heat on it. Be careful though, if you don't know what you are doing, you can burn out the paint.
Old Jul 11, 2008 | 08:01 PM
sykou's Avatar
It looks like it could be that some one painted the trunk before and instead of removing the letters, they just cleared over them.... Is the clear around the outlines raised higher than the inner part of the letters?
Old Jul 12, 2008 | 04:14 PM
eyekyu's Avatar
when i debadge my 02 i used a blow dryer and some spray detail and rubbed the **** out of it. also it was already about 102 outside i left my *** end in the sun for a couple hours.
oh yeah also those letters have been in the same place for 4 years the color diff will be there for a while
