Porblem with HID
Old Oct 20, 2008 | 09:58 PM
anwyn's Avatar
Porblem with HID
Hi guys, i installed my HID kit, and have a problem with the "default" light that you can't turn of. The light start to blink and is very annoying and possibly will damage my HID, so i have to turn the lights on even in the day so that it doesn't blink.
Any suggestions?
Old Oct 20, 2008 | 09:59 PM
dipsetinallday's Avatar
Your battery is low. When it has enough power your hids wont blink. Your welcome.
Old Oct 20, 2008 | 10:09 PM
4no's Avatar
4no
battery is not low, DRLs haven't been disabled which is why it's flickering. please search, there is a guide on how to "disable DRLs"...it's a simple plug behind the drivers headlight i believe
Old Oct 20, 2008 | 10:25 PM
brads09lancerGT's Avatar
I installed mcculloch HID xenons and they do the same thing. I called a tech @ xenonking or something and they said something like there is too much current running thru the DRL that's why they flicker then shut off after a minute or so. I read a few threads about wiring them into the parking or side markers but I didn't want to wreck anything. Easy enough to just turn on the lights
Old Oct 21, 2008 | 10:55 PM
Never mind.
Old Oct 21, 2008 | 10:58 PM
Do you have fog, low, and high beams on your car and are they all using hids? If so what watt hids are used on each.
Old Oct 22, 2008 | 08:22 PM
the owners manual that came with my sets says that they use 35W and 3.5A. That seems low because they are freakin bright. They all use seperate ballasts
