help pleaseeee , i need help
Old Dec 24, 2008 | 05:08 PM
Bergen Automotive's Avatar
i replaced my stock seats today in my (2006 lancer es) with some racing seats, i had to fabricate some custom brackets for them to fit, the drivers side is done and i reattached the sensor on the bottom and put everything and all works, when i sit and plug in the seat belt the sensor on the dash goes off, but the passenger seat seatbelt sensor does not go off when u plug in the seat belt, and also you know how when with the stock seat a passenger sits the sensor under the clock turns off, it does not so that anymore, and my srs sensor in my dash lit up, do any of you know how to get these to work again , the sensor is on the buttom of my custom brackets for the passenger seat and are plug in but still does not work, please help me out guys, thanks
Old Dec 24, 2008 | 05:15 PM
help
Old Dec 24, 2008 | 05:20 PM
also i dont think the airbag for the driver will deploy since the srs in the dash in on too!! wat u guys think?
Old Dec 24, 2008 | 05:41 PM
someone help me pleaseeee, i cant drive my car right now cause if i get in a crash i will die. lol please help me.
ambystom01's Avatar
If the SRS is engaged, the airbags essentially shutdown. Try going over the connections again to make sure they're all there. It may be that you used the wrong connector somewhere.
Old Dec 24, 2008 | 05:43 PM
thank you soo much for replying to my thread, i checked over all the connects and still, the srs light and the seat belt light for the passenger is still on even thou i plug in the seat belt for the passenger, this is really annoying.
Old Dec 24, 2008 | 05:53 PM
is there any plugs besides the ones under the seats that i can check? or only those front two under the seat?
Old Dec 24, 2008 | 05:56 PM
ambystom01's Avatar
There should only be the plugs under the seat. You might want to look into resistors.
Old Dec 24, 2008 | 06:18 PM
how do i do that? i don't understand
thanks
Old Dec 24, 2008 | 06:24 PM
ambystom01's Avatar
You can use resistors to trick the car into thinking all the sensors are working as they should.
Old Dec 24, 2008 | 07:06 PM
doctorjon's Avatar
The passenger seat belt warning light relay could be out. Also you could try to reset the SRS.
Old Dec 24, 2008 | 07:08 PM
how do i reset the srs? and how would i install/use resistors to trick the computer.
Old Dec 24, 2008 | 07:28 PM
anyone know how to reset srs light?
Old Dec 24, 2008 | 07:29 PM
ambystom01's Avatar
Reset the ECU by disconnecting the battery for 20 minutes.
Old Dec 24, 2008 | 07:39 PM
ok, i just disconnecte the battery and ima wait for 30 min and try again, thanks for the help, if anyone else has any ideas please feel free to chip in, thanks
