help pleaseeee , i need help
Old Dec 24, 2008 | 07:47 PM
jahnnybravo's Avatar
If you were working on the seat and had turned the ignition to the 'ON' position while a sensor or any part of the warning lamp circuit was unplugged, it's possible that is the cause of the SRS light. The SRS-ECU will detect an open circuit and set a DTC. If that's the case, you will need to go into the SRS-ECU diagnostics to retrieve and clear the code. I'm not sure if there is any way to access these codes with a generic non-Mitsubishi scan tool, but you can try. Clearing the code will fix it if the code was for an open circuit and if all the connectors are now secured...... If that's not the problem, then you may have a problem with the seat sensor. There is a calibration procedure that may need to be performed for the passenger seat sensor, assuming that the sensor is installed in a manner that will allow it to function correctly. This procedure will require a factory scan tool to perform. PM me if you need any more info.
Old Dec 26, 2008 | 10:27 PM
Update? Did you take it into your tech today to have it scanned?
Old Dec 26, 2008 | 11:33 PM
drucea's Avatar
Yeah I'd have to say it's in the system from unplugging it and disconnecting the battery will probably reset it.
Old Jan 10, 2009 | 05:47 PM
Tadz0rz's Avatar
take it to your dealer, they can reset your srs lamp
RA11226
Evo X How Tos / Installations
120
Jun 24, 2022 03:19 AM
bdean531
Dec 19, 2016 05:30 AM
tiesto14
May 18, 2016 01:19 PM
NightHawk
15
May 31, 2013 11:42 AM
kcandiloro
Nov 24, 2009 12:55 PM
