power problem.. fuses?
Old May 16, 2009 | 06:49 PM
scorpionx13's Avatar
so i was just about to leave to arkansas when i figured out that >>3<< of my windows did not roll down (not drivers side), my underseat neons did not power on (not a big deal, but ya know), and my power outlet did not work.
i was just wondering if anyone has had this before. could all these be related to bad fuses??
i did* move some cable in the trunk to plug up my bass... but it was just shifting around, and it was the trunk cables after all.
thanks for all your help!
Old May 16, 2009 | 09:12 PM
sonic_evox's Avatar
well first off all did you check if any of the fuses were blown out?
Old May 17, 2009 | 03:29 PM
3 windows easy fix. cig lighter - im gonna have to open up the dash in order to get to that fuse box. if the fuse thread is not broken then im not gonna know where to go from there and that would be a waste of time haha.
with the 4 neon bars, im just gonna have to check if powers getting to them somehow. and if not, then i guess they are burnt out
Old May 17, 2009 | 04:38 PM
sonic_evox's Avatar
what do you mean open up the dash, the fuses arent located behind the dash, unless i miss understood you, but the problem might be bad wiring with your neon bars, other than that your best best would be to check for blown out fuses like i said before because a month ago my power outlet wasn't working and it turned out to be a blown fuse.
Old May 17, 2009 | 08:17 PM
yea thanks for the posts lankid.
it actually was a blown fuse for the power outlet. finally put one in and got my radar det working. i just could get back there with the dash and wires in the way and such... until i realized that you could take that little dropdown compartment out to give you a better view lol... sorry im still learning small lancer things
yea i guess i will check on the wiring on the neons tomorrow or something.
OO and my engine was sputtering at neutral afterwards and stalled in the driveway..................hopefully its just the engine adjusting to the plugs i pulled out, checked, and put back in haha.
Old May 17, 2009 | 10:55 PM
sonic_evox's Avatar
haha, thats the only reason i wanted to fix my power outlet too, and for the fuse box, yeah all you have to do is pull out the little dropbox, thats why i was confused when you said you needed to open up the dash, and about the engine sputtering, im not so sure. But goodluck tho
Old May 19, 2009 | 09:27 AM
yup sputtering of engine was just temp from the fuses going in and out. and the inside neons are prob burnt out im guesssing
alright, u can erase mod
Darkn3s
Nov 20, 2013 07:49 AM
mossontree
Oct 28, 2013 10:26 AM
EvoCats2011
Feb 19, 2013 09:38 PM
Darkn3s
Feb 11, 2013 07:52 PM
proverb
Lancer How Tos / Installations
Sep 24, 2007 11:38 AM
