Lowering spring problems
Old Jun 10, 2009 | 10:19 AM
JCPT's Avatar
anyone has installed the TEIN S-TECH lowering springs to the Lancer 08, do you guys had or have any problem with the steering? Every time i turn the steering wheel to any direction there is something that sounds like broken, and is only in the front/right side wheel where it sounds, before with the stock springs this was not happening. any suggestion?
Jean
Old Jun 10, 2009 | 10:33 AM
02-Lancer-Es's Avatar
Same thing happened to mine(I own 2 Lancers a 08 and 02 ) , it was a strut not tightened enough.
Take off the wheel and tighten all the bolts , do the same with the top mount bolts ( Center and 3 around.
Old Jun 10, 2009 | 10:37 AM
kanyonkid's Avatar
what he said, i dont have those springs, but my rrm's would actually "knock" over bumps until they were broken in...
Old Jun 12, 2009 | 06:26 AM
JCPT's Avatar
right now i left the car in the mitsubishi factory they will check it, and should fix it, i would tell you what was wrong and how they fix it, if "they fix it", and about the broken in, i have like 3 weeks with the springs installed, how many days did you wait for the springs to broken in "kanyonkid"?
Jean
Old Jun 12, 2009 | 09:11 AM
That was the worst thing you could have done , now your warranty will be voided and they will not fix it .
Sorry to tell you , but unless you have a good friend there you made a bad choice .
Old Jun 12, 2009 | 10:42 AM
Stuntfly02's Avatar
Its possible that you didn't set them into the seat on the strut/mount correctly and they made noise until they seated themselves. I can't be sure as I don't have the springs to compare my experience to, but this was an issue for a few people when they were first released.
Old Jun 15, 2009 | 02:14 PM
JCPT's Avatar
they didnt fix it, the sounds remains...they told me that the sound is the result of lowering the car , i would go to another place, and about the warranty you say it right "unless a good friend" . Now im thinking, could the front/right spring be damaged?
Old Jun 15, 2009 | 05:12 PM
So did they try and void the warranty ?
What else did they say about lowering the car?
Or did it not go to the dealer?
Old Jun 16, 2009 | 10:37 AM
JCPT's Avatar
no they didnt told me anything about the warranty, they just told me that for the installation I should have take the car to them to ensure the springs to not give any problems, like now...and with the warranty i changed the window plush so i think there is no problem.
