vacuum gauge help
Old Oct 29, 2009 | 10:58 PM
sonic_evox's Avatar
vacuum gauge help
hey guys i got my gauges hooked up today thanx to marcus(link62) and im having problems getting the vacuum hose thru the firewall, where do i get thru and then once thats done where do i hook it up cause the im not sure which hose would be best to check my vacuum, any help is appreciated!
Old Oct 29, 2009 | 11:25 PM
06redrocket's Avatar
there should be rubber inlets for where the harness goes into the car. Just poke a hole threw that and there are plenty of vaccum lines in the engine bay . You can use the brake booster hose which is right above where the line needs to go threw the firewall .
Old Oct 29, 2009 | 11:33 PM
sonic_evox's Avatar
i tried putting it thru the one whole that has a rubber inlet on the passenger side and i see noting coming out from the inside, and which hose do you mean cause my friends 03 es has a hose coming right from the intake manifold but mine doesnt have that
Old Oct 29, 2009 | 11:36 PM
ok use a hanger and poke it threw on the drivers side and im talking about the brake booster which u can google a pic of . its located on the drivers side right above where u need to poke threw the firewall. U can tap into it and you wont have to use that much hose.
Old Oct 29, 2009 | 11:45 PM
sonic_evox's Avatar
i think i know which one you mean but its to huge to fit on the tee
Old Nov 3, 2009 | 02:06 PM
twardnw's Avatar
if you do hook up your vacuum gauge to the booster line, make sure you put it before the check valve, you won't get accurate readings if it is on the booster side of that valve. Best place to tap into for the gauge would be the line leading to the FPR.
Old Nov 3, 2009 | 09:22 PM
link62's Avatar
he has an 05 so he doesnt have an fpr or the vaccum nipple on the side of the IM thats why he wondering what to tap in to
Old Nov 3, 2009 | 10:38 PM
twardnw's Avatar
ah, wasn't aware there was that much of a difference.
Old Nov 3, 2009 | 10:42 PM
link62's Avatar
yea i found that out when i was helping him out lol
Old Nov 3, 2009 | 10:54 PM
sonic_evox's Avatar
i actually got it hooked up, noel from westek gave me some advice on where it was nice to tee into it, its running perfect all i need is to get my piggyback installed and im still waiting on rrm for the throttle body
Old Nov 3, 2009 | 11:42 PM
link62's Avatar
really i would like to see a pic of where its tee in to
Old Nov 4, 2009 | 12:04 AM
sonic_evox's Avatar
ill take a picture tomorrow and ill post it up
Old Nov 4, 2009 | 12:17 AM
link62's Avatar
kk oh and i got the pics we took on my photobucket ill send u a pm to the link
Boostagsr
Jun 21, 2013 09:04 AM
superkizuna
Mar 26, 2012 09:29 PM
JohnBradley
Lancer Troubleshooting
Jul 2, 2008 11:41 PM
crasher
Jan 9, 2007 04:36 AM
Bobby12many
Jul 31, 2004 03:19 PM
