View Poll Results: Survey says
Wilwood
6.67%
AP Racing
17.78%
Brembo
33
73.33%
Others Please Post
2.22%
Voters: 45. You may not vote on this poll
Best Brakes???
Old Jul 10, 2002 | 05:45 PM
2wdSQL's Avatar
Best Brakes???
Who really has the best stopping power? Which brands are best for what use? Which are the most cost effective? Long-term reliability?
Old Jul 10, 2002 | 07:32 PM
Wallesasuaz's Avatar
brembo Brembo BREMBO
BREMBO BREMBO BREMBO........
Old Jul 10, 2002 | 07:51 PM
ChrisEVO's Avatar
Endless of course... you can't go wrong with Brembo or AP though. AP 6 pot...yummm
Old Jul 10, 2002 | 08:26 PM
b_tapper's Avatar
Stoptech or wilwood
wilwood 6pots
Old Jul 10, 2002 | 08:27 PM
b_tapper's Avatar
What about AEM? they make great kits too.
Old Jul 10, 2002 | 08:31 PM
Lan Evo's Avatar
I guess it's not which is the "best", but suitable for your use. Even with a racing brake, you wouldn't be able to stop the car if the brakes are not heated up
For regular street use, brembo caliper with project u (mu) pads and brake lines should be good enough. However, on competition level, that's another story...BTW, Ralliart used AP on the Grp A EVO...
Old Jul 10, 2002 | 09:59 PM
ChrisEVO's Avatar
I have the stock 4 pot Brembos on my VII with Endless NA-S pads...the car stops on a dime.
Old Jul 10, 2002 | 11:29 PM
bbvc's Avatar
I pick ENDLESS
Old Jul 11, 2002 | 06:01 AM
shirokuma's Avatar
Best brakes are a subjective thing - what's your usage?
For example, if you are mainly driving on the street, with a bit of windy road driving, then relatively soft pad that heat up quickly are best, such as the Titan Kai's I'm using. On the street, such pads with decent calipers, such as brembo or nearly any 4-pots, will be more than you need or use.
However, once you get to the track, street pads will die a horrible death, your brake fluid will turn into a light fluid resembling water, and you'll learn what brake fade means. Then heftier calipers that dissipate heat well, steel/mesh brake lines, high temperature brake fluid, racing rotors, and pads that work well at high temperature ranges are needed. Then you can start looking at upgrades past the Brembo systems, like Wilwoods. But, your street braking will suffer, since you will rarely get the brakes warm enough to work optimally...
Me, I stick with some standard 4-pots in the front, racing 2-piece rotors, mesh lines and DOT 4.5 fluid, but have somewhat soft Titan Kai pads on. They actually last on the track a bit, though they grind down rather quick, and on the street there's actual bite.
Paul Hansen
Old Jul 11, 2002 | 06:16 AM
2wdSQL's Avatar
I was looking at the Wilwood calipers Billet Superlite 4 Piston all around silly I know but I like unformity.
Old Jul 15, 2002 | 03:37 AM
pjal84's Avatar
Dunno if anyone mentioned it but what about Baer?
Old Jul 15, 2002 | 04:05 AM
b_tapper's Avatar
They are all pretty good, but are useless unless you race your car. I can't see spending $6k for a look
Old Jul 16, 2002 | 10:04 AM
tanders's Avatar
Exclamation
I'd say Brembo with an upgraded Brake hose and Pads. I have Ralliart Pads and steel braided brake hose in my car and the brakes are great! Better than stock.
Old Jul 16, 2002 | 11:03 AM
ROCK's Avatar
Big brakes are only good if the pads you use are good.
ROAD/RACE
http://www.roadracemotorsports.com/
Old Jul 16, 2002 | 11:04 AM
3171's Avatar
why would anyone buy brakes for looks?
also, no matter what you do to the original (Brembo) brakes (pads, steel-braided hoses, etc.) you will warp the discs under hard use. Am know on my second set of discs after 4,000miles.
