View Poll Results: Survey says
Wilwood
6.67%
AP Racing
17.78%
Brembo
33
73.33%
Others Please Post
2.22%
Voters: 45. You may not vote on this poll
Best Brakes???
Old Jul 17, 2002 | 05:35 AM
shirokuma's Avatar
I've been using some australian 2-piece rotors, by a fine company named DBA at
http://www.dba.com.au/
and they've held up quite well even after several track sessions. Going by the temp paint on the outside edge, I and another user have gotten them very hot (+600 degrees celcius, or farenheit, I can't remember which), and they haven't warped yet. They are not that cheap, but not that expensive either, depending on your location.
Paul Hansen
Old Jul 17, 2002 | 06:22 AM
3171's Avatar
thanks Paul, will definitely consider when my current set go. I am in Singapore so it should not be too hard to find
Old Jul 17, 2002 | 09:04 AM
GDB's Avatar
GDB
Brembos 4-pot paired with Project Mu's HC-Titan Kai are great, but can't stand too much abuse on the track (a tad of fade and sponginess but the latter must be due to the brake lines).
AP's 6-pot is the way to go, if "best" means "cost no object" as well.
I *heard* that Wilwood's stopping power may be good, but it won't last long.
For street use, even a 2-pot will do. Why would anyone need such strong brakes on the streets anyway?
3171 - Yo I've seen several dBA's at Espace before, MAYBE they have them.
Old Jul 17, 2002 | 09:08 AM
3171's Avatar
GDB,
Running the stock calipers with Endless rotors now, not bad on the track, better than stock. However, I have been advised that these will warp. will worry about that when it happens.
how's the car? hope everything is in order now
Old Jul 17, 2002 | 09:09 AM
b_tapper's Avatar
That's what I keep saying
I actually need brakes though...it's amazing how much they fade after 2 laps on the track. Guess getting subaru 4pots, wrx front rotors, and h6 rotors in the rear will help my car out.
Old Jul 18, 2002 | 06:39 AM
GDB's Avatar
GDB
3171 - Which Endless rotors are you using, if you don't mind me asking? The one with 6 slits?
Your stock calipers are Brembos, 4-pot in front 2-pot in the back, right?
My car is fine now thank you very much Still need more mileage though before I have full confidence attacking it around the track again.
Old Jul 18, 2002 | 10:40 AM
3171's Avatar
gdb,
yup, i am using the one with the 6 slots and the blue centre (did not realize it at the time but it matches my car).
have not been to the track since the last time i saw you there. really need to go soon
Old Jul 18, 2002 | 08:06 PM
FastLaneTuning's Avatar
Okay, here's my question... I've looked all over for brake upgrades for my Lancer... Nothing major, just something with more bite and longer life. So far all I've seen are the Carbon/Kevlar pads. Has anybody actually made a "brake kit" for the OZ Lancer?
I feel like I need something more... My Aurora had 4 wheel disks, and I replaced the rotors AND pads once a year... I also autocrossed the car, just to learn a little about FWD handling, but still... It was rediculous how fast I burned those brakes off... I would sometimes get out of the car after a "spirited" drive through the mountains, and the left rear caliper would be smoking... Anyway, I just don't want to have to go through brakes in this car like I did in the other... I hope the difference in weight will help me out a little.
Old Sep 19, 2002 | 07:36 PM
HobieKopek's Avatar
No one makes a big brake kit that isn't custom yet and you probably shouldn't NEED anything bigger. But hey...I loves me some big ole brakes so I can sympathise with you.
Old Sep 20, 2002 | 12:42 AM
lancer02Josh's Avatar
do they make a kit for the us lancer
Old Feb 24, 2004 | 07:54 PM
oz-e's Avatar
brembo's own my soul...
Old Feb 24, 2004 | 07:55 PM
bobaab's Avatar
this is a bad survey..
Old Feb 28, 2004 | 06:58 PM
Conduit's Avatar
I'll take some of the 8 piston, liquid cooled AP racing touring car calipers. Yum.
Old Feb 28, 2004 | 07:03 PM
LancerEvoMR's Avatar
After 2 years....
Closed.
michiganevoix
19
Nov 3, 2014 11:36 PM
Noogie
Jan 8, 2009 10:59 PM
bmaga123
Apr 12, 2005 08:51 PM
batty
Nov 11, 2004 08:11 PM
The Emperor
10
Jul 29, 2004 02:48 AM
