What gas are you guys using?
Old Apr 20, 2012 | 09:05 PM
4g94T's Avatar
Originally Posted by nj_08_gts
Loading premium in does nothing but create incomplete combustion cycles - it will not burn as cleanly as regular fuel assuming a stock engine/compression. Premium won't give you more power or a cleaner engine - in a stock N/A Lancer, it's a waste of money.
How does it create an incomplete combustion cycle?
The sensors will compensate the AFR to 14.7
Most tuners only tune the WOT areas in your map anyways.
So while cruising or driving normally, you're on stock values.
Old Apr 20, 2012 | 09:55 PM
ambystom01's Avatar
Originally Posted by CrAnSwIcK
high octane fuel burns slower so you can tune for that by advancing timing, and it is also more compressible so you can run a leaner AFR without knocking...factory tune and stock compression ratio, premium fuel will make your car slower before it makes it faster, and like nj_08_gts said, you'll get incomplete combustion...
since i last posted here, i turbocharged my engine, and i'm still running 91...
I don't think this is 100% correct. I haven't found any evidence saying that octane is related to burn speed, as 87, 89 and 91 octane all have the same energy (assuming you're not mixing extra crap like ethanol in there). Octane purely relates to resistant against knock. Using a higher octane than needed is just pissing money away, it change the performance characteristics of the car.
Old Apr 20, 2012 | 11:11 PM
CrAnSwIcK's Avatar
most gas stations i see have little stickers on them that say they "may" contain up to 10% ethanol...and everyone should knows alcohols are a high octane, slow burning fuel...but regardless, it's the fact that it's burning slower that it's reducing the likelihood of knock occuring...
Old Apr 20, 2012 | 11:18 PM
ambystom01's Avatar
Do you have a source for that? Everything I've read so far suggests otherwise, namely that the fuels burn just as fast. It makes sense to me that it would burn slower but who knows. The problem with ethanol is it also reduces the energy content of the fuel.
Old Apr 20, 2012 | 11:24 PM
ambystom01's Avatar
http://www.stockcarracing.com/techar...l/viewall.html
This would suggest that octane rating has nothing to do with burn speed. It is purely an indication of resistance to knock. If you have no knock, the burn speed is the same. If you get knock though, this speeds up the burn because you get flame fronts from multiple sites.
Old Apr 21, 2012 | 12:18 AM
CrAnSwIcK's Avatar
i've just always heard that, and not from randoms, like mechanics, and guys that build engines for a living...and even the source you posted doesn't actually say for sure that it doesn't, but that there's no conclusive evidence that it does... they just go one to say that it for sure is more resistant to heat and pressure...i checked a few other sources, inluding this random google search and they say similar things, not that it for sure doesn't burn slower, but there's no solid evidence...they only say what they know for sure, which is quite common knowledge (temperature/pressure resistance)...but then the say stuff like, "burn rate is a function of several variables, and the two are completely independent, although there is generally a correlation between octane ratings and burn rates."
this is confusing, it's like saying "high octane fuel doesn't burn slower, but generally higher octane fuels tend to burn slower"...it's like nobody even knows for sure.
Old Apr 21, 2012 | 12:22 AM
ambystom01's Avatar
Regardless, for the OP's purposes, higher octane is a waste of money.
Old Apr 21, 2012 | 05:56 AM
02modlanceroz's Avatar
http://forum.ih8mud.com/80-series-te...cts-myths.html
Old Apr 21, 2012 | 03:51 PM
CrAnSwIcK's Avatar
oh for sure, non-turbo, stock compression and tune, high octane is like like burning money cause it feels better than burning newspaper...
Old Apr 21, 2012 | 04:21 PM
4g94T's Avatar
I'd like to see someone log their stock Lancer on 87 octane and see if it doesnt knock...
Old Apr 21, 2012 | 06:49 PM
CrAnSwIcK's Avatar
i run 87 in my 03 ES...it's bone stock...i don't datalog anything because it's stock...but what open source software can i use to log knock sum? I have an openport 2.0 cable that i use for tuning my Ralliart...
Old Apr 21, 2012 | 10:36 PM
4g94T's Avatar
I use mitsulogger with the tactrix 1.3U.
I've always wanted to log my car when it was stock, but the technology didnt exist back then
It'd be interesting to see
Old May 9, 2012 | 07:19 AM
lippy1306's Avatar
87 on a stock lancer
hutch959
Aug 18, 2016 04:23 PM
supercharged
Jun 19, 2009 08:08 PM
plokivos
Southeast Region
41
Jan 3, 2005 10:39 AM
