Need Help ! What is the difference between...
Old Jul 6, 2014 | 07:33 AM
DiamondPrincess's Avatar
Question Need Help ! What is the difference between...
What is the difference between these lights and what do you recommend?
http://www.protuninglab.com/hidxe08milae2.html
http://www.protuninglab.com/08milaevoxle2.html
http://www.protuninglab.com/08miecdrlled2.html
Old Jul 20, 2014 | 04:46 PM
gotsniff's Avatar
The "HID Xenon + 08-13 Mitsubishi Lancer / Evo X LED DRL Projector Headlights - Gloss Black" uses a halo ring and a bulb of ur choosing to light the main headlamp and the bulb is filtered through a lens
The "2008-2012 Mitsubishi Lancer Evo X Angel Eye Halo & LED DRL Projector Headlights - Smoked" uses only a halo ring to light the main headlamp
And the "08-13 Mitsubishi Lancer / Evo X LED DRL Projector Headlights - Gloss Black" does not have a white halo ring to light the main headlamp, but does have the glass lens for a bulb of your choosing .
I would go with the cheapest option "08-13 Mitsubishi Lancer / Evo X LED DRL Projector Headlights - Gloss Black" but I'm not really into halo rings. If you are DIEing to have a halo ring I would go with "HID Xenon + 08-13 Mitsubishi Lancer / Evo X LED DRL Projector Headlights - Gloss Black"
The halo ring of the "2008-2012 Mitsubishi Lancer Evo X Angel Eye Halo & LED DRL Projector Headlights - Smoked"doesn't seem like it would provide enough light by itself to me. You would probably end up using your high beams all of the time with these headlights
gotsniff's Avatar
Old Jul 20, 2014 | 04:58 PM
mitsuozboi's Avatar
The difference, basically is the type of Bulb that is used. The HID projector headlights (the most expensive) will have the best light output but will require you to do some wiring to add the ballasts if your car did not come with HID's.
Halogen headlights should be plug and play but will not be any brighter than stock.
all three lights still use a low beam bulb. Not sure what you mean when you say
Smoked"doesn't seem like it would provide enough light by itself to me. You would probably end up using your high beams all of the time with these headlights"
Soxman
Sep 25, 2016 01:28 PM
DaEvoBull
Jul 8, 2014 09:54 AM
Bimmubishi
Apr 13, 2005 09:04 AM
