Newbie seeking aftermarket steering wheel hub info!
Old Dec 20, 2018 | 01:36 AM
RobXombie's Avatar
Hi. I'm new to the forum so hopefully it's ok to post this here. So I'm trying to install an aftermarket steering wheel & I've gone through 2 eBay steering wheel hub adapters for my '02 Lancer ES, that didnt work. Even though both posts stated they were for an 02 Lancer. The center hole with the grooves, was alittle too small on both hub adapters. Ive tried to do research on this, but most links are no longer good & I couldn't find much info on this. Could someone please hold my hand & walk me through this? Or possibly post links to some correct hub adapters needed to install an aftermarket steering wheel on an 02 Lancer ES? Thanks in advance.
Old Dec 20, 2018 | 06:45 AM
Hey Rob. Welcome aboard. I moved your thread to the Lancer section
Ill try searching for ya on this topic but please search & see if you can locate some info
Thanks, Joe
Edit: @RobXombie Heres a thread you might find informative: https://www.evolutionm.net/forums/la...ub-anyone.html
