Grounding Wires
Old Jun 13, 2004 | 09:26 PM
camaro379ss's Avatar
Grounding Wires
Where can I find a good set of grounding wires and for how much?
P.S. Can you post a link to the site.
Old Jun 14, 2004 | 12:45 AM
ghostrider's Avatar
It makes a fun DIY. Run a search for grounding wires and I'm sure you'll find the diagram of all the grounding points in the Lancer.
Old Jun 14, 2004 | 01:21 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Yeah, you can DIY or order an ebay kit or get the name brand stuff. One place for the Lineage brand is www.vividracing.com try them if you want to spend top dollar.
Old Jun 14, 2004 | 05:15 PM
richozlancer's Avatar
how do i install the hyper ground system to my car?
Old Jun 14, 2004 | 09:03 PM
hanahawaiian's Avatar
Also u can go Dealership.. go part service they sell ground kit too and Diagram and pics
Old Jun 14, 2004 | 09:14 PM
Moderator
Bomb Squad Unit #02
^ That's actually probably the best idea. I would assume that Mistu has done testing to see where is best to place the wires. From what I hear, you won't gain much unless everything is put in the right order and location, and that can only be found by dyno testing.
Old Jun 22, 2004 | 04:00 PM
Guack007's Avatar
Do I have to run all 5 cables that come with the lineage grounding kit or will just a few help. The reason is because I wont want to remove the airbox or upper pipes for about a month or two.
Old Jun 22, 2004 | 06:55 PM
why not call or ask Service part dept for mitsu and ask them and they have diagram
Old Jun 23, 2004 | 12:55 AM
OZnate's Avatar
what are the advantages of using a grounding kit?
Old Jun 23, 2004 | 01:12 AM
Moderator
Bomb Squad Unit #02
apparently, it gives you less sympathetic noise through your stereo system and electrical controls. Also, if tuned properly, it can give you a few extra horsepower.
