How to change a clutch???
Old Jul 18, 2004 | 10:25 PM
gregivq's Avatar
Arrow How to change a clutch???
Can anyone give me directions (pics/or txt) or tips how to change
a clutch disc in 2002 OZ stick???
thx
Old Jul 19, 2004 | 10:04 AM
LancerEvoMR's Avatar
Moving to USLG.
Old Jul 22, 2004 | 10:47 PM
AznFlip's Avatar
get a money, find some good shop, and let them do it.
Old Jul 22, 2004 | 10:48 PM
AznFlip's Avatar
dont do it if you not sure how to do it or dont have any clue...have someone do it for you and watch them how to do it.
Old Jul 23, 2004 | 05:11 AM
gregivq's Avatar
thx
Old Jul 23, 2004 | 07:20 AM
HobieKopek's Avatar
A gross simplification:
Remove driver side wheel, disconnect your suspension from the half shaft. Drop the sub frame, unbolt the tranny from the block, pry it open, unbolt the pressure plate, remove pressure plate, remove clutch. Have fun. Not something I'd want to spend a weekend doing when you could have it done for me. I'm glad I had BM Tranny (now merged with Turbo Trix Racing) do mine. Saved me a big headache.
Old Jul 23, 2004 | 07:33 AM
siantjab's Avatar
It is most definately something you don't want to attempt if a) you have no lift, b) don't have adequate tools, and c)haven't done in the past. It is by no means easy at all.
Old Jul 23, 2004 | 11:50 AM
AznFlip's Avatar
unless you're in auto class or something
Old Jul 23, 2004 | 12:03 PM
HobieKopek's Avatar
Tools aren't a big deal. You can easily do this with an impact wrench and/or sockets and a pry bar (to open the tranny and disconnect suspension), but you do NOT want to be doing this without a lift. It's REALLY hard to work under there without the space. If you have access to a shop...sure it's a lot for one person, but doable.
Old Jul 23, 2004 | 12:16 PM
gregivq's Avatar
Pictures anyone???
Or intructions?
I KNOW A LOT OF PEOPLE WOULD APPRECIATE IT.
Old Jul 23, 2004 | 01:20 PM
HobieKopek's Avatar
Not many people have done clutch installs. I doubt you're going to find many people with pictures, if any at all. And unless someone has been quiet a long time or watched/participated in their clutch install like I did or Road Race decides to take and post pics, I doubt they're gonna get posted. Service manual may be your best bet. Again though, not something I'd wanna try without a lift. And this coming from someone who did his own rods, pistons and rings in his driveway (and still hasn't had the time to finish putting it all back together ).
Old Jul 23, 2004 | 01:25 PM
AznFlip's Avatar
if u want you see instructions with pictures on how to do it, you might just want to buy Chilton Repair Manual, but i dont know if they published for 02-03 lancer yet.
Old Jul 23, 2004 | 01:29 PM
siantjab's Avatar
You can get the manuals off EBay for about $20. They are in PDF format and will have all the assembly/dissassembly info you need. I have one for my evo. Good luck!
Old Jul 23, 2004 | 01:38 PM
AznFlip's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Oct 23, 2004 | 05:13 PM
ozracer4's Avatar
what all should you change out if you upgrade your clutch and pressure plate...i heard you should get a new throw-out bearing and resurface the flywheel, but what's up with the pilot bearing and the imput shaft bearing that i've been hearing about?
