2nd cat or resonator
Old Jul 19, 2004 | 12:19 AM
electr0's Avatar
some people told me i have a secondary catalytic converter, and some say its a resonator? which is it?
also, will removing the 2nd cat/resonator make it smog illegal? thanks
Old Jul 19, 2004 | 12:24 AM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
You have all 3. The 1st cat (precat) is in the exhaust manifold. Then comes the resonator, then the 2nd cat (normal cat). From what I hear, removing any of them makes it fail smog legally and visually, but some people say the 1st cat doesn't show up on the sniffer test.
Old Jul 19, 2004 | 12:43 AM
digdat's Avatar
not to correct you UK ... but its first cat in exhaust manifold, second after the down pipe, and resonator after 2nd cat.of course this is on a stock exhaust.
Old Jul 19, 2004 | 12:45 AM
pumpdog720's Avatar
diggydat is correct
Old Jul 19, 2004 | 11:22 AM
Moderator
Bomb Squad Unit #02
Thanks, I actually wasn't sure.
Old Jul 19, 2004 | 11:25 AM
Lancer03oz's Avatar
we need an aftermarket exhaust manifold! I live in indiana and we don't have smog test n **** like that!
Old Jul 19, 2004 | 11:32 AM
jc7651's Avatar
let me tell you this from experience... removin the Cat and Then the resonator makes your car POP.
you can see the test pipe, and then a straight resonator eliminator. the straight is clamped in the pic but i have since welded the sh*t outta it. Ha. Peace out
Old Jul 19, 2004 | 12:34 PM
electr0's Avatar
so removing the resonator would make me fail smog?
Old Jul 19, 2004 | 12:42 PM
Moderator
Bomb Squad Unit #02
Not sure about the resonator, I don't think it has anything to do with emissions so you should be fine. But someone who knows more about it come in here and give your .02
Old Jul 19, 2004 | 12:57 PM
Danno's Avatar
There is no point of removing your resignator. Its usuless to do so, all it does is control where the exhaust resignates. Without it your car will be louder but not faster (and thats heat score) you will not gain any power, well okay maybe .05% or something trivial. But regardless its not worth it. As far as your Removing one or all of your Cat's. It depends on where you live and how tight they are on there emissions. Removing both is almost a guarintee to fail but if you were to remove one and drive your car around for a few hours before the test it will be okay (should be). Cat's work best when they are hot. There is 2 on the Lancer because it was needed when the car was cooler. Just remove the first one (with headers) and then keep your stock stuff. If you Fail emissions put your stock stuff on and try again. Then after you pass...switch it back
Cheers
Danno
Old Jul 19, 2004 | 04:25 PM
4g94T's Avatar
theres no fine for failing? i got headers and left the second cat alone
Old Jul 19, 2004 | 04:28 PM
electr0's Avatar
i live in california where emissions is real bad.. i dont even think i can remove a cat at all....
Old Jul 19, 2004 | 11:22 PM
Moderator
Bomb Squad Unit #02
Yeah, california is harsh. If they notice that you tampered with any emissions devices, they can fail you without even running the test, and if they report that, your car can be listed as a gross polluter and will be required to get an emissions test every year!
Old Jul 19, 2004 | 11:27 PM
TeamNeXusOz's Avatar
i have already gotten pulled over in so cal for my header...(since thats all he sited me for)..but you wont pass smog with the header on...
Old Jul 20, 2004 | 12:50 PM
4g94T's Avatar
that sucks, how did the cop know you got a header on?
