guide on how to un-install tail lights
Old Jul 20, 2004 | 07:15 PM
ctchome's Avatar
Hi,
is there any link regarding removal of tail lights?
i had search thru the forums, can't seems to find any ..
thanks a lot guys .
Old Jul 20, 2004 | 07:23 PM
rentaslut's Avatar
just pop the trunk and you'll see a few screws, its really easy.
Old Jul 20, 2004 | 07:25 PM
Iamkar33m's Avatar
pop the trunk and ull see 2 phillips screws holding each light in. Unscrew em and there are 2 ball and socket joints that hold the other end of the tail in. Tug the taillight out gently.
Old Jul 20, 2004 | 07:29 PM
ctchome's Avatar
hi, thanks for your prompt reply,
erm ... okay, just to check with you,
do i have to remove the grey piece of plastic in the middle ? where the hook is ..
what about the clips for the tail light ?
sorry, i have not tried yet, i hope to find some pictures to guide me ..
thanks.
Old Jul 20, 2004 | 07:31 PM
yellance's Avatar
It should unplug and the whole thing should come right off
Old Jul 20, 2004 | 07:36 PM
ctchome's Avatar
wow ... i just notice that it's 2.30am over your side ..
don't you guys need to sleep ??
thank you so much for your reply .. i guess i will be trying out tonight and
if i encounter any problems, i get back to you all again ...
btw, isn't there a link on how to remove the tail light ?
i thought there is ...
hmm .... have a great night ahead ..
Old Jul 20, 2004 | 07:45 PM
ctchome's Avatar
you mean i just have to remove the 2 philips screw and i can slowly tug the tail
light out ?
don't i have to remove the internal linings behind the tail light ?
Old Jul 21, 2004 | 07:59 AM
discreet303oz's Avatar
light out ?
No, the whole tail light pops right out. Unscrew the screws, grab each side of the tail light, and just wiggle back and forth until it pops off. Then you just unclip the wiring and you're good to go!
Old Jul 21, 2004 | 07:06 PM
ctchome's Avatar
depo gun metal tails
hi discreet, thanks a lot.
i have done that last night and it works !
surprisingly, its not very tight ... and it's kinda lose ...
probably cause it's taken out a couple of times when changing the
bulbs . any solutions to tighten it ?
The other thing is does anyone of you have problems with depo gun metal tail
lights ? especially water leakage ? The sealing doens't look very good with the
large gaps ...
lastly, thanks a lot for all the help.
