Need Exaust Help (rattle)
Old Jul 23, 2004 | 02:44 PM
DjDoubt's Avatar
It's the sway bar I'm going to try the heater hose idea.
Old Jul 23, 2004 | 03:10 PM
TURBOit's Avatar
yup, works like a charm
Old Jul 24, 2004 | 11:43 PM
hardcoretuner's Avatar
do you have a testpipe? if not its prob your cat. i had the rrm header and a 2.5 buscher exhaust and i had the same prob, got a test pipe and it was all goood. my exhaust is loud as **** but what you gonna do. a high flow cat would do the same. i looked at my cat before and it was a solid mass of foam and then i looked at it after i got my header and it had a small ray of light going through the center. lol. too much air too fast for it i guess.
edit: i thought it was my sway bar too and i wrapped that part of the exhaust with heat tape and still heard the noise.
Old Jul 25, 2004 | 10:05 PM
.L.'s Avatar
.L.
djdoubt
i have the exact same setup you have bro. the only time my exhaust pops is when i first start my car (cold motor). after driving around for a couple minutes, it dosent pop at all no matter how hard i drive it. as far as noise/rattling, just make sure everything is bolted up correctly, nice and tight.
Old Jul 26, 2004 | 02:59 PM
DjDoubt's Avatar
Hey Guys Did the heater hose thing. who ever though of the was a fkng einstine.
Thnks
Old Jul 26, 2004 | 03:11 PM
jsfour's Avatar
yah i would just checkt the bolts....
Old Sep 3, 2004 | 09:14 PM
Evojun8's Avatar
Do You Have To Reset The Ecu When U Get A New Exhaust System. Does It Help
Old Sep 3, 2004 | 09:24 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
If you get a muffler or a catback, you don't really need to reset the ECU. If you get a header, high flow cat, and/or test pipe, you'll need to reset it.
