Need Exaust Help (rattle)
Old Jul 21, 2004 | 08:03 PM
DjDoubt's Avatar
Hey Guys,
I just installed my KAMKIKAZE headers. I have a dc sports TCS exaust. When I'm idling aor run the ac the whole system rattles. Is there an easy way to fix this. By the way as a novice in cars I was able to install the headers them self but it was a pain in the A$$ took about 6hours 1 trip to auto azone, and plenty of beer after the install. lol Also can I get rid of the CEL without a MIL elliminator or can I just pull the bulb from behind the dash?
Thanks
Old Jul 21, 2004 | 08:05 PM
nightrider's Avatar
did u try resetting ur ecu. it helped my rattles at idle a little bit.
Old Jul 22, 2004 | 12:28 PM
DjDoubt's Avatar
Not yet but sounds like a good Idea
Old Jul 22, 2004 | 12:30 PM
TampaTurbo's Avatar
Did you check to make sure your exhaust is bolted tight or if it is resting on another piece of metal under the car?
Old Jul 22, 2004 | 12:32 PM
urbanknight's Avatar
Moderator
Bomb Squad Unit #02
Yep, check to make sure the exhaust has a few inches clearance from all other parts and adjust the hangers if necessary.
Old Jul 22, 2004 | 05:37 PM
DjDoubt's Avatar
Thanks for the info guys. I am also hearing a POP kind of like a mini backfire when i shift between 1st and 2nd at higher RPMs. Is this ok? is it fed up? How can I tell if i have an exaust leak?
Old Jul 22, 2004 | 11:38 PM
Moderator
Bomb Squad Unit #02
If it's a pop like pressure coming out of the exhaust, that's just the exhaust going from blow to suck when you let off the gas and relieve the pressure of the drive train. Shouldn't be a problem. You might even hear it when slowing down to a stop.
Old Jul 22, 2004 | 11:43 PM
TURBOit's Avatar
sometimes i notice the exhaust system hits the sway bar, if it is, its an easy fix
Old Jul 23, 2004 | 12:52 PM
DjDoubt's Avatar
How Could I fix this?
Old Jul 23, 2004 | 12:53 PM
DjDoubt's Avatar
That sounds right. I kinda of sounds like a light back fire
Old Jul 23, 2004 | 12:56 PM
siantjab's Avatar
Get under the car and shake the exhaust in a few places. See if you can hear it underneath the car. You may just need to massage one of the hangers a bit.
Old Jul 23, 2004 | 12:58 PM
DjDoubt's Avatar
How do I massage the hangers? I have never heard that term b 4
Old Jul 23, 2004 | 12:59 PM
DjDoubt's Avatar
Hey Can I just pulg the O2 sensor from the old headers and keep it in the engin bay to keep the CEL off
Old Jul 23, 2004 | 01:24 PM
TURBOit's Avatar
If your exhaust system hits your sway bar to the right, here is how you stop it from rattling. Go to home depot and buy "Heater Hose", it is a black tube fairly thick. Cut it length wise so that you can open it up and wrap it around your sway bar, cut it long enough to fit the area where your exhaust piping is. then just use regular clamps to tight both ends around the sway bar. Works like a charm and shouldn't cost more than 5 or 10 dollars.
Old Jul 23, 2004 | 01:27 PM
siantjab's Avatar
The whole exhaust system is hung on rubber hangers. You may need to get a smaller or longer one in one or two locations to create some clearance. Get under the car and have a look and you'll see what I'm talking about. The are like rubber donuts with holes top and bottom; and they are rather cheap to buy.
