taking off our hand brakes
Old Jul 31, 2004 | 06:16 PM
Go_Lancer_Go's Avatar
Question taking off our hand brakes
does n e one know how to take off our hand brakes???
Im trying to install a new one (a sparco one) and i dunno how to get ours off...
Old Aug 2, 2004 | 01:58 AM
petey pab's Avatar
once youve got the center console out, you should just be able to pull it off.
Old Aug 2, 2004 | 06:46 AM
rguija's Avatar
This is to remove the hand brake handle right?
Old Aug 2, 2004 | 10:04 AM
hows that possible??? can u explain in a lil more detail
Old Aug 2, 2004 | 10:07 AM
HobieKopek's Avatar
To take off the handle just twist and pull. It's glued on, so it takes a lot of effort the first time. After that it gets easier. If you can't do it with your hands (sissy boy) then use a towel and a vice grip. To take off the whole assembly however, you must remove the center console (which is simple).
Old Aug 2, 2004 | 04:03 PM
petey pab's Avatar
^^^yeah, what he said....
Old Aug 2, 2004 | 07:33 PM
deeznuts's Avatar
HAHAHA he call a sissy boy J/k....HAHAHA
Old Aug 2, 2004 | 11:27 PM
is there n e way to replace the button that releases the hand brake?
im installing a new sparco one if that helps n e
Old Aug 3, 2004 | 06:42 AM
HobieKopek's Avatar
If I remember correctly (I haven't had mine apart in a while) the hand brake assy is just a wire with a button all wrapped in a piece of sheet metal that's attached to a hinge. It can probably be done, but I doubt it's worth the trouble.
