How can i remove a dent, whats the best way?
ask one of the dealeer if they knew someone like a dent wizard here in cali we have a dent wizard they fixed my dings without a scratch charge me $90.00
Yes, they work and they are known as PDR(Paintless Dent Repair) a technique developed by Mercedes-Benz back in the 80s, if the dent is not creased, they can message the metal out to 95-100% of the original form without bondo and painting within 30 minutes. Will cost anywhere from $30-$100cdn depending on the difficulty of the repair.
Is bondo hard to work with?
Problem with bondo is that you will have to repaint the whole fender after patching it and since with PDR its the original metal and paint your car will still be noted as original and not repainted when you try to sell it.
Here's what I would do: go buy "ding king" or one of those $20 dent removers (provided the metal isn't really warped). Worst case scenario- it doesn't work, you're out $20, and might be able to get a refund from the store. Then go ahead and find a place that does that paintless dent repair.
Bondo is a pain to work with if you've never done it before, and/or aren't very patient (it takes a lot to gt it just right).... then you need to get colormatched paint, primer and a clearcoat with the proper "softeners" in it to repaint the whole fender.... then it can pop off if that spot gets bumped again
Gooseman396
Apr 23, 2012 05:32 PM
nsadams87xx
Feb 3, 2012 06:11 PM
sepandee
Toronto Lancer Club
17
Apr 3, 2010 03:46 PM
