View Poll Results: What's a good next step in performance mods?
RRM Header
72.73%
RRM Intake Manifold
18.18%
RRM Throttle Body
9.09%
Voters: 11. You may not vote on this poll
What Next?
Old Aug 9, 2004 | 07:30 AM
sthiewes's Avatar
What Next?
I've been trying to do some searches on my next project. I have a Weapon R intake with a Magnaflow cat-back exhaust system. What should be my next performance upgrade? I have 4 things in mind: 1. Piggy Back ECU 2. Header 3. Intake Manifold and 4. Bored Throttle Body. What do you think would be the next best upgrade with my setup that I have?
Old Aug 9, 2004 | 09:48 AM
HobieKopek's Avatar
Moving out of drivetrain tech as this is neither technical nor drivetrain related. Plus try to post in the most specific forum possible, and pay attention to what forum you're in while creating a new thread.
Old Aug 9, 2004 | 09:59 AM
psionic98's Avatar
next mod is up to you and it all depends on how much money you have to spend... overall the next mod that will probably see the most gain will be the ECU, however, the ecu will always fair better if the rest of those mods are in place ahead of it... plus with ecu you need to use premium gas, and the other mods you dont..
Old Aug 9, 2004 | 10:07 AM
ZooRacer's Avatar
u can get the boring done at local places for half the costs!
Old Aug 9, 2004 | 10:54 AM
sthiewes's Avatar
so piggy back ecu should be last b/c it makes everything else perform better. Probably the header should be next?
Old Aug 9, 2004 | 11:27 AM
discreet303oz's Avatar
Well, the way I'm doing it is I'm starting w/ Intake, like you have and I'm working my way around in a hook towards the headers on out to the exhaust. That's before the FI goes in. So...
Intake - > TB - > Manifold - > Header - > Exhaust
Then just like Psionic98 said, get the ECU last because that will make everything else perform better. Just my .02 and what I have planned for my car. Good luck w/ whatever you do, it's a very expensive hobby we're into!
Old Aug 9, 2004 | 11:49 AM
sthiewes's Avatar
Yeah i know it's an expensive hobby...but fun. As long as the ECU is last I can basically get the throttle body, header or intake manifold next then? I wasn't sure if there was a specific order they had to be in to perform the best.
Old Aug 9, 2004 | 02:31 PM
Hellacious's Avatar
Header
Old Aug 9, 2004 | 03:26 PM
ghostrider's Avatar
Header also. It's the biggest bolt-on gainer you can add outside of the piggyback.
Old Aug 9, 2004 | 03:45 PM
4g94T's Avatar
yea headers, then piggy
Old Aug 10, 2004 | 05:28 AM
sthiewes's Avatar
What about manifold and throttle body? Shouldn't I do that before ecu too? Also will headers make my car sound too loud b/c I have a magnaflow cat-back system on too? If it does how do I prevent that?
Old Aug 10, 2004 | 05:52 AM
ghostrider's Avatar
The header will increase both the volume and pitch of your exhaust; making it louder and higher pitched. How much depends on: 1) the size piping your header will be 2) the size piping your exhaust will be.
In my cases I had the RPW header/downpipe (2.5" downpipe size) dump into a RRM testpipe (2.25") followed by stock piping and ending in a RMR axleback (2.25") piping and I removed the testpipe the same day I installed it because the exhaust was way too high pitched.
Then I had the same header/downpipe dump into the 2nd cat followed by a JIC-Magic catback (2.5") and it was loud and deep.
Now I have the same header/downpipe dump into a custom 2.5" testpipe followed by the same catback and it's loud and deep enough to set of alarms when I remote start my car.
As for getting the manifold and tb, you don't have to get them done before the ecu. The parts will provide the same gains in the end no matter what order you get them in. I'd get the header then the ecu (remember you have to run 91 or better octane at all times) because they provide the biggest gains. I'd do a testpipe/highflow cat next, the intake manifold after that and the tb last. That should give you the biggest gains with each mod and by the time you get around to the manifold and tb, you'll have plenty of power already to make the gains from the two items more significant.
Old Aug 10, 2004 | 06:06 AM
sthiewes's Avatar
Thanks ghostrider for the info. Sounds good. So that'll give me some pretty good hp gains. Thanks for your help.
Old Aug 12, 2004 | 03:29 AM
ghostrider's Avatar
No problem. That's what we're here for.
Xdhallettx
Mar 1, 2012 04:48 PM
mattz09
39
Jun 18, 2010 11:02 PM
lousEVOxmr
Mar 12, 2010 08:01 PM
2 step
Mar 15, 2009 07:04 PM
trn5014
Nov 9, 2007 11:16 AM
