what should my next step be?
hello, Im wondering what my next modification should be and wanted to see what your guys think! I have a 2005 evo 8 mr. I have an evo 9 turbo running 23.5 psi, manual boost controller, 5 speed tranny swap with an act clutch, cold air intake, a turbo back megan racing exhaust with test pipe, coilovers waiting to go in, defi gauges, aftermarket head unit, and a short shifter with aftermarket base bushings. What should i do next? I was kind of thinking of doing cams, but don't you have to do springs and valves and all that if you do cams? I was also possibly thinking of getting my turbo upgraded.. i dunno what is everyones opinion? thanks!
well right now i dynoed at like 340 to the wheels.. Id like to get closer to the 400 range for right now considering the internals are still stock. should i also be looking at a bigger fmic? and which cams could i get away with?
ohh i forgot i have a 255 walbro so that takes care of that.. i need to write down a list lol and i can get away with just putting those cams in without doing springs and all that?
Thanks for posting your whp. Because come this weekend, I will have the same setup as you. I already have a turboback exhaust and manual boost controller and this saturday I'm getting an evo 9 turbo, 255 fuel pump, custom licp, and an Invidia o2 housing + tune.
And eventually I plan to go for GSC cams and a ETS FMIC.
As far as your next step, you could port your intake and exhaust manifold, convert to E85, or install a meth kit.
e85 is kind of a no go for me because unfortunately there aren't really any stations around. And thanks for all the input guys! oh and i actually enjoyed the difference with the solid base bushings, i felt like it made the shifting a lot more stiff and complemented the short shifter pretty well as far as smoothness.. @ runker goo luck with your tune, and enjoy!
WTB[West]: Aftermarket 272 cams for an EVO 8
AWDSON
Sep 18, 2015 12:21 PM
her name is eva
Sep 13, 2013 09:09 PM
LordHighBinary
Apr 9, 2004 02:11 PM
