going crazy with engine
Old Aug 17, 2004 | 10:36 AM
bahamut's Avatar
That's a lot of stuff. You really need to think the project through and try to make it more cost effective. When you start climbing the cost near 50% of your car's resale value, you should have some cold feet.
Once you go down that road, there is no turning back.
sleek_concepts's Avatar
actually i am building a show vehicle, i will probably only race the car every once in a while. this car is going to be my daily driver so.
i think the magnaflow exhaust is going to be my best bet.
i am also forgoing some extensive body work and custom interior work.
Old Aug 17, 2004 | 10:37 AM
pgmike's Avatar
Originally Posted by sleek_concepts
i like the cam shaft and valve cover idea. i was actually thinking about those. yeah i forgot to ask which exhaust would be the best one to run. which exhaust does everyone recommend??
since you are getting a turbo do NOT get a magnaflow or greddy like everybody is saying. they are jsut 2.25 inches and a 2.5 is better with a turbo. get the buschur downpipe, hi flo cat, and catback that has a magnaflow muffler on it. you also have the option of a custom made 2.5 straight thru turboback but that would be very loud and very illegal.
Old Aug 17, 2004 | 10:38 AM
i dont want anything really loud, i want something that sounds good but still performs. i will check out the bruschur one.
Old Aug 17, 2004 | 10:40 AM
gregivq's Avatar
i didnt get a tranny, i am getting the manual transmission turbo.
Where can I find one?
pgmike's Avatar
Originally Posted by twinkiemobile
Well i'm pretty sure that if you get the stage 2 turbo from RRM.. you would get new injectors and a piggyback unit.. But if I were you, it seems you're going to be doing some heavy duty racing.. Why don't you just buy the non-ic.. and the i/c pipes from RRM.. take of your front Re-inforcement bar and stuff a mammoth a*s Intercooler in there.
i do not recomend getting a "mammoth" IC, another member did that and lost power with that IC over the rrm spearco one. also if you did want to get the larger IC do not just get the nonIC kit. you can get the IC kit without the intercooler and not have to cut and weld the turbo to turn it around to accomadate an IC.
Old Aug 17, 2004 | 10:42 AM
gregivq's Avatar
Originally Posted by Automatic 51
unless your gona race more than drive on the street, i'd forgo the flywheel. yes it does increase throttle response but street drivablitiy is less enjoyable. so i'd prolly do that last if you've got the money to burn.
you could also go with the powder coated valve cover, and a cam shaft upgrade. not sure how much those are off the top of my head.
Is poweder coated valve cover that important?
How does it benefit you?
Old Aug 17, 2004 | 10:43 AM
pgmike's Avatar
performance wise, it doesnt benefit you. jsut a show mod.
Old Aug 17, 2004 | 10:50 AM
psionic98's Avatar
one thing I dont think I saw in your first post... get the ported intake mani... unless someone else said it and I overlooked it... since you are going all out, mine as well have everything the same size! Maybe also get 1 range colder plugs to accomodate the heat of the engine
Also, if you do decide to get cams/gears you will probably need an AEM EMS or some engine management because RRM's stage 2 turbo has a reprogrammed ECU that is set for factory cams I believe... might wanna talk to someone before going after cams
Old Aug 17, 2004 | 10:52 AM
pgmike's Avatar
also think about getting some great sticky tires.
how much boost you wanting to run?
Old Aug 17, 2004 | 11:44 AM
pumpdog720's Avatar
Hey Tim talk with me, I'll help you out on what you should and need to get for your car performance wise... just IM me sometime on AIM...
...one good performance mod would be a turbo for MY car, that would make your car so much better, just believe me, it will...
Old Aug 17, 2004 | 12:52 PM
ghostrider's Avatar
Originally Posted by Centrylancer
why not just get an evo?
forgo the upgrading of the oz and get the evo/rs/ or wait a few more wks and get the MR!!!
That's what I'd be doing too. Hell, if I had the full 250 large to blow, I'd be doing anything other than modding my Lancer. I'd mod my dealership's used lot with it (and I've done a good bit) and buy a brand new car.
Old Aug 17, 2004 | 01:16 PM
neilschelly's Avatar
You mentioned potentially getting the willwood drilled/slotted kit and kevlar pads. Bad combination. Drilled rotors shouldn't be combined with kevlar pads or you won't be able to stop worth anything. They will never get hot enough to be effective. Go with a good street compound and drilled rotors or stick with just a slotted pair of rotors and get the carbon kevlar pads.
-N
RobertK's Avatar
I would turn around and start another business if I had 250k to blow.
Old Aug 17, 2004 | 01:55 PM
well some of the money is going into my business. some of the money is remodeling my house. the rest is going to my personal account. which means that some will go into my car. if i wanted an evo, i woudl have bought an evo at the dealership. i wanted a lancer that i could mod out. not an evo that comes modded out. im in this game for the show aspect and the evolution gets looks when you drive it off the lot, there is no challenge in that for me. now making my car faster and better looking than an evo would be a challenge and thats what i want to do. thanks for the thoughts on the brakes. ill keep them in mind.
