Indiglo gauges!!!
Old Aug 23, 2004 | 06:32 AM
sthiewes's Avatar
Indiglo gauges!!!
OK...I have the instructions on installing the indiglo gauges for the ES. I was able to get the cluster out but not unplugged. I know this sounds like a silly question but how do you unplug it? I could not get the gauge cluster out from the wires. What I'm I doing wrong? Can anyone help?
Old Aug 23, 2004 | 06:40 AM
KAOTIK's Avatar
there was a little clip that u had to push down to pull it out but i dont know if it is the same for the ES
Old Aug 23, 2004 | 06:43 AM
sthiewes's Avatar
There is two sets of wires connected to the cluster that need to be unplugged. Just push down on the tab and pull out the wire.
Old Aug 23, 2004 | 06:51 AM
sthiewes's Avatar
It says to splice positive wire into positive wire of the parking lights. Which wire is the parking lights?
Does it also just slide over the original gauges? No need to remove needles right?
Old Aug 23, 2004 | 07:19 AM
sthiewes's Avatar
Anyone?
Old Aug 23, 2004 | 07:25 AM
Centrylancer's Avatar
pics?
Old Aug 23, 2004 | 07:38 AM
sthiewes's Avatar
Sorry no pics
Old Aug 23, 2004 | 07:48 AM
sthiewes's Avatar
If anyone replaced there gauges I'm sure they know what I mean. When the cluster is out it's hooked up to 2 sets of wire harnesses that need to be unplugged. I can't unplug it. Kaotik said "I had to push down on two little clips then pull it out." I need to know how to: 1. unplug wire harness? 2. which wire is the parking lights? 3. Does the gauges just slide over original and 4. if I need to remove the needles? Thanks
Old Aug 23, 2004 | 08:01 AM
Kid Lancer 7's Avatar
ok...
#1 those instructions that came with it..SUCK! lets iron that out..
to answer your questions....
#4 DONT REMOVE the needles!!.
#3 YES! SLIDE them over your stock guage.. theese are complete overlays!
#2 I didnt know which lights were the parking lights at the time.. so i Spliced them up to the dimmer . I forgot which color wire to connect with what.. but just do a lil trial and error.).. the lil dimmer switch thats below the steering wheel to the left.
#1 no need to unplug ur wire harness.. Unplug ur battery!!! when you are doing this! you dont wanna blow a fuse (even though they are super cheep to repleace.. but lets just avoid that situation.!)
this looks so bad *** at night!
Old Aug 23, 2004 | 08:09 AM
sthiewes's Avatar
Do I need to remove the dimmer switch since it came w/ a new one?
Old Aug 23, 2004 | 08:20 AM
keep everything.. lemme find my post about this (from last year )
Old Aug 23, 2004 | 08:31 AM
sthiewes's Avatar
ok...Let me know
Old Aug 23, 2004 | 08:44 AM
sthiewes's Avatar
Any luck...kid lancer 7?
Old Aug 23, 2004 | 08:48 AM
https://www.evolutionm.net/forums/sh...everse+indiglo
post#67... not my write up.. but its is correct!
Old Aug 23, 2004 | 08:52 AM
Goodluck man! (sorry no pics though)
BUT, take your time..... his write up ^^^ will definitely get you through!
now i have to go primer my techsport kit!
