know your history/back in the day
Find parts to fit the CD9A Evolution
View Model details for the CD9A Evolution
Start of Production:October 1992Number Produced:5000Length [mm]:4310Height [mm]:1395Width [mm]:1695GSR Weight [kg]:1240RS Weight [kg]:1170Chassis Code:CD9AEngine Size:1997Bore and stroke:85.0 x 88.0Compression Ratio:8.5:1Power [bhp]:247Torque [lb/ft]:228Injector Size [cc]:5100-60mph:5.1 secs0-100mph:13.7 secsTop Speed [mph]:143Fuel Consumption:21Fuel Tank capacity:48 LitresTransmission:5 Speed manualActive Yaw Control [AYC]:NoActive Center Dif [ACD]:NoGear Ratio 1st [GSR/RS]:2.750/2.750Gear Ratio 2nd [GSR/RS]:1.684/1.684Gear Ratio 3rd [GSR/RS]:1.160/1.160Gear Ratio 4th [GSR/RS]:0.862/0.862Gear Ratio 5th [GSR/RS]:0.862/0.862Gear Ratio Rev [GSR/RS]:3.166/3.166Gear Ratio Final [GSR/RS]:5.443/5.443
Find parts to fit the CE9A Evo II
View Model details for the CE9A Evo II
Start of Production:Jan 1994Number Produced:5000Length [mm]:4310Height [mm]:1420Width [mm]:1695GSR Weight [kg]:1250RS Weight [kg]:1180Chassis Code:CE9AEngine Size:1997Bore and stroke:85.0 x 88.0Compression Ratio:8.5:1Power [bhp]:257Torque [lb/ft]:228Injector Size [cc]:5100-60mph:5.0 secs0-100mph:13.5 secsTop Speed [mph]:147Fuel Consumption:21Fuel Tank capacity:48 LitresTransmission:5 Speed manualActive Yaw Control [AYC]:NoActive Center Dif [ACD]:NoGear Ratio 1st [GSR/RS]:2.750/2.750Gear Ratio 2nd [GSR/RS]:1.684/1.684Gear Ratio 3rd [GSR/RS]:1.160/1.160Gear Ratio 4th [GSR/RS]:0.862/0.862Gear Ratio 5th [GSR/RS]:0.617/0.617Gear Ratio Rev [GSR/RS]:3.166/3.166Gear Ratio Final [GSR/RS]:5.443/5.443
Find parts to fit the CE9A Evo III
View Model details for the CE9A Evo III
Start of Production:Jan 1995Number Produced:7000Length [mm]:4330Height [mm]:1420Width [mm]:1695GSR Weight [kg]:1260RS Weight [kg]:1190Chassis Code:CE9AEngine Size:1997Bore and stroke:85.0 x 88.0Compression Ratio:9.0:1Power [bhp]:266Torque [lb/ft]:228Injector Size [cc]:5100-60mph:4.9 secs0-100mph:13.3 secsTop Speed [mph]:149Fuel Consumption:22Fuel Tank capacity:48 LitresTransmission:5 Speed manualActive Yaw Control [AYC]:NoActive Center Dif [ACD]:NoGear Ratio 1st [GSR/RS]:2.750/2.750Gear Ratio 2nd [GSR/RS]:1.684/1.684Gear Ratio 3rd [GSR/RS]:1.160/1.160Gear Ratio 4th [GSR/RS]:0.862/0.862Gear Ratio 5th [GSR/RS]:0.617/0.617Gear Ratio Rev [GSR/RS]:3.166/3.166Gear Ratio Final [GSR/RS]:5.443/5.443
Find parts to fit the CN9A Evo IV
View Model details for the CN9A Evo IV
Start of Production:August 1996Number Produced:9000Length [mm]:4330Height [mm]:1415Width [mm]:1690GSR Weight [kg]:1350RS Weight [kg]:1260Chassis Code:CN9AEngine Size:1997.5Bore and stroke:85.0 x 88.0Compression Ratio:8.8:1Power [bhp]:276Torque [lb/ft]:260Injector Size [cc]:5100-60mph:4.8 secs0-100mph:12.9 secsTop Speed [mph]:150Fuel Consumption:23Fuel Tank capacity:48 LitresTransmission:5 Speed manualActive Yaw Control [AYC]:YesActive Center Dif [ACD]:NoGear Ratio 1st [GSR/RS]:2.750/2.750Gear Ratio 2nd [GSR/RS]:1.950/1.950Gear Ratio 3rd [GSR/RS]:1.407/1.407Gear Ratio 4th [GSR/RS]:1.031/1.031Gear Ratio 5th [GSR/RS]:0.761/0.761Gear Ratio Rev [GSR/RS]:3.416/3.416Gear Ratio Final [GSR/RS]:4.529/4.529
Find parts to fit the CP9A Evo V
View Model details for the CP9A Evo V
Start of Production:Jan 1998Number Produced:6000Length [mm]:4350Height [mm]:1415Width [mm]:1770GSR Weight [kg]:1360RS Weight [kg]:1260Chassis Code:CP9AEngine Size:1998.6Bore and stroke:85.0 x 88.0Compression Ratio:8.8:1Power [bhp]:276Torque [lb/ft]:275Injector Size [cc]:5600-60mph:4.8 secs0-100mph:12.9 secsTop Speed [mph]:155Fuel Consumption:24Fuel Tank capacity:48 LitresTransmission:5 Speed manualActive Yaw Control [AYC]:YesActive Center Dif [ACD]:NoGear Ratio 1st [GSR/RS]:2.928/2.785Gear Ratio 2nd [GSR/RS]:1.950/1.950Gear Ratio 3rd [GSR/RS]:1.407/1.444Gear Ratio 4th [GSR/RS]:1.031/1.096Gear Ratio 5th [GSR/RS]:0.720/0.761Gear Ratio Rev [GSR/RS]:3.416/3.416Gear Ratio Final [GSR/RS]:4.529/4.529
Find parts to fit the CP9A Evo VI
View Model details for the CP9A Evo VI
Start of Production:Jan 1999Number Produced:7000Length [mm]:4350Height [mm]:1415Width [mm]:1770GSR Weight [kg]:1360RS Weight [kg]:1260Chassis Code:CP9AEngine Size:1998.6Bore and stroke:85.0 x 88.0Compression Ratio:8.8:1Power [bhp]:276Torque [lb/ft]:275Injector Size [cc]:5600-60mph:4.8 secs0-100mph:12.9 secsTop Speed [mph]:155Fuel Consumption:24Fuel Tank capacity:48 LitresTransmission:5 Speed manualActive Yaw Control [AYC]:YesActive Center Dif [ACD]:NoGear Ratio 1st [GSR/RS]:2.928/2.785Gear Ratio 2nd [GSR/RS]:1.950/1.950Gear Ratio 3rd [GSR/RS]:1.407/1.444Gear Ratio 4th [GSR/RS]:1.031/1.096Gear Ratio 5th [GSR/RS]:0.720/0.761Gear Ratio Rev [GSR/RS]:3.416/3.416Gear Ratio Final [GSR/RS]:4.529/4.529
Find parts to fit the CP9A Evo VI TME
View Model details for the CP9A Evo VI TME
Start of Production:Jan 2000Number Produced:5000Length [mm]:4350Height [mm]:1415Width [mm]:1770GSR Weight [kg]:1360RS Weight [kg]:1260Chassis Code:CP9AEngine Size:1998.6Bore and stroke:85.0 x 88.0Compression Ratio:8.8:1Power [bhp]:276Torque [lb/ft]:275Injector Size [cc]:5600-60mph:4.8 secs0-100mph:12.9 secsTop Speed [mph]:155Fuel Consumption:24Fuel Tank capacity:48 LitresTransmission:5 Speed manualActive Yaw Control [AYC]:YesActive Center Dif [ACD]:NoGear Ratio 1st [GSR/RS]:2.928/2.785Gear Ratio 2nd [GSR/RS]:1.950/1.950Gear Ratio 3rd [GSR/RS]:1.407/1.444Gear Ratio 4th [GSR/RS]:1.031/1.096Gear Ratio 5th [GSR/RS]:0.720/0.761Gear Ratio Rev [GSR/RS]:3.416/3.416Gear Ratio Final [GSR/RS]:4.529/4.529
Find parts to fit the CT9A Evo VII
View Model details for the CT9A Evo VII
Start of Production:March 2001Number Produced:10000Length [mm]:4455Height [mm]:1450Width [mm]:1770GSR Weight [kg]:1400RS Weight [kg]:1320Chassis Code:CT9AEngine Size:1998.6Bore and stroke:85.0 x 88.0Compression Ratio:8.8:1Power [bhp]:276, 300 [FQ Model]Torque [lb/ft]:282, 300 [FQ Model]Injector Size [cc]:5600-60mph:4.7 secs0-100mph:12.7 secsTop Speed [mph]:155Fuel Consumption:24Fuel Tank capacity:48 LitresTransmission:5 Speed manualActive Yaw Control [AYC]:YesActive Center Dif [ACD]:YesGear Ratio 1st [GSR/RS]:2.928/2.785Gear Ratio 2nd [GSR/RS]:1.950/1.950Gear Ratio 3rd [GSR/RS]:1.407/1.444Gear Ratio 4th [GSR/RS]:1.031/1.096Gear Ratio 5th [GSR/RS]:0.720/0.825Gear Ratio Rev [GSR/RS]:3.416/3.416Gear Ratio Final [GSR/RS]:4.529/4.529
Find parts to fit the CT9A Evo VII GT-A
View Model details for the CT9A Evo VII GT-A
Start of Production:Jan 2002Number Produced:2000Length [mm]:4455Height [mm]:1450Width [mm]:1770GSR Weight [kg]:1480RS Weight [kg]:N/AChassis Code:CT9AEngine Size:1998.6Bore and stroke:85.0 x 88.0Compression Ratio:8.8:1Power [bhp]:276Torque [lb/ft]:253Injector Size [cc]:5500-60mph:5.5 secs0-100mph:13.8 secsTop Speed [mph]:155Fuel Consumption:25Fuel Tank capacity:48 LitresTransmission:6 Speed manual or autoActive Yaw Control [AYC]:YesActive Center Dif [ACD]:YesGear Ratio 1st:2.928Gear Ratio 2nd:1.950Gear Ratio 3rd:1.407Gear Ratio 4th:1.031Gear Ratio 5th:0.720Gear Ratio Rev:3.416Gear Ratio Final:4.529
Find parts to fit the CT9A Evo VIII
View Model details for the CT9A Evo VIII
Start of Production:Jan 2003Number Produced:5000Length [mm]:4455Height [mm]:1450Width [mm]:1770GSR Weight [kg]:1380RS Weight [kg]:1300Chassis Code:CT9AEngine Size:1998.6Bore and stroke:85.0 x 88.0Compression Ratio:8.8:1Power [bhp]:276, 300, 330
[FQ Models]Torque [lb/ft]:289, 300, 305
[FQ Models]Injector Size [cc]:5600-60mph:4.5 secs0-100mph:12.5 secsTop Speed [mph]:160Fuel Consumption:24Fuel Tank capacity [GSR/RS]:55/50 LitresTransmission:5 or 6 Speed manualActive Yaw Control [AYC]:YesActive Center Dif [ACD]:YesGear Ratio 1st [GSR/RS]:2.909/2.785Gear Ratio 2nd [GSR/RS]:1.944/1.950Gear Ratio 3rd [GSR/RS]:1.434/1.444Gear Ratio 4th [GSR/RS]:1.100/1.096Gear Ratio 5th [GSR/RS]:0.868/0.825Gear Ratio 6th [GSR/RS]:0.693/NAGear Ratio Rev [GSR/RS]:3.416/3.416Gear Ratio Final [GSR/RS]:4.583/4.583
Find parts to fit the CT9A Evo VIII MR
View Model details for the CT9A Evo VIII MR
Start of Production:Feb 2004Number Produced:3000Length [mm]:4455Height [mm]:1450Width [mm]:1770GSR Weight [kg]:1400RS Weight [kg]:1340/1310*Chassis Code:CT9AEngine Size:1998.6Bore and stroke:85.0 x 88.0Compression Ratio:8.8:1Power [bhp]:300, 320, 340
[3 FQ Models]Torque [lb/ft]:Between 300-320Injector Size [cc]:5600-60mph:4.6 secs0-100mph:12.5 secsTop Speed [mph]:160Fuel Consumption:24Fuel Tank capacity [GSR/RS]:55/50 LitresTransmission:5 or 6 Speed manualActive Yaw Control [AYC]:YesActive Center Dif [ACD]:YesGear Ratio 1st [GSR/RS]:2.909/2.785Gear Ratio 2nd [GSR/RS]:1.944/1.950Gear Ratio 3rd [GSR/RS]:1.434/1.444Gear Ratio 4th [GSR/RS]:1.100/1.096Gear Ratio 5th [GSR/RS]:0.868/0.825Gear Ratio 6th [GSR/RS]:0.693/NAGear Ratio Rev [GSR/RS]:3.416/3.416Gear Ratio Final [GSR/RS]:4.583/4.583
Find parts to fit the CT9A Evo VIII 260
View Model details for the CT9A Evo VIII 260
Start of Production:Feb 2004Number Produced:2000Length [mm]:4455Height [mm]:1450Width [mm]:1770GSR Weight [kg]:1470RS Weight [kg]:N/AChassis Code:CT9AEngine Size:1998.6Bore and stroke:85.0 x 88.0Compression Ratio:8.8:1Power [bhp]:261 [more like 285!]Torque [lb/ft]:261 [more like 270!]Injector Size [cc]:5600-60mph:6.1 secs
Boost limited in 1st0-100mph:UnknownTop Speed [mph]:152Fuel Consumption:25Fuel Tank capacity:55 LitresTransmission:5 Speed manualActive Yaw Control [AYC]:YesActive Center Dif [ACD]:YesGear Ratio 1st:2.928Gear Ratio 2nd:1.950Gear Ratio 3rd:1.407Gear Ratio 4th:1.031Gear Ratio 5th:0.720Gear Ratio Rev:3.416Gear Ratio Final:4.529
