Help! Which bolt for RRM Rear STRUT??
Can someone please tell me if it matters which set of bolts i attach the rrm rear strut in the trunk too?? I cannot get one of the bolts loose... the picture shows the two that are closer to the front of the car but i cant get one of the bolts off... can i just bolt down to the trunk facing pair?? Quick response please.. thanks.
i actually have my RRM rear strut bar on my bolt closest to the rear of the car and I have my RRD rear strut bar on my bolt closest to the back seat. I also have the RRM front KBar and the RRD rear lower tie bar and the RRD Trunk brace and I am getting the RRM sway bar.
i mean, bars are good and all, but 2 rear strut bars and a tie bar? come on
actually, i am not joking. I ordered the trunk brace from PDXRalliart and he sent me the rear strut bar instead. I left him a message saying he sent me the wrong bar and he said he was sorry (which I believe, mistakes happen), he told me to keep the bar and he'll send me the trunk brace right away. So the extra rear strut bar was sitting in my garage and I decided "**** it" I'll put it on anyways. I haven't had any problems. I'm looking forward to getting my RRM rear sway bar to help with understeer as I'm looking to do autocross this spring.
2 rear strut bars
- 1 RRM
- 1 RDD
1 RS trunk bar
1 tie bar
And you are waiting on a progress sway bar... make sure to get an alignment bro.
Fox
just got an alignment last week when I put my summer wheels back on. No problems. But i'll get another one when I get the sway bar on.
My front left tire went flat and I went into get it checked out. The front tire going flat had nothing to do with the bars, the stock Yoko's just suck goat nuts, but they checked my front alignment and it was out of wack. The rear was fine, but I'm pretty sure that it was messed up from Mitsubishi. You just don't go through a set of tires in under 25K miles. And I don't drive hard on my tires at all.
But you should always go get an alignment after any suspension modification.
Fox
03_Lancer_ES
Jan 25, 2007 07:13 PM
pgmike
17
Feb 20, 2005 10:58 AM
Kurt
12
Oct 10, 2002 10:05 PM
Link286XT
12
Jun 23, 2002 11:38 AM
