Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
How To Change The Color of Your Gauge Needles
Old Apr 9, 2005 | 12:49 AM
Z_Lancer_Man's Avatar
Arrow How To Change The Color of Your Gauge Needles
How To Change Your Needle Colors
Green, Yellow, White, Red, or Blue
Note: Taking apart your gauge cluster isn't difficult, but the gauges are sensitive pieces of equipment. As with all How-Tos, you do this at your own risk.
Tools/Supplies Needed
  • Phillips screwdriver for removing the gauge cluster
  • Exacto knife or sharp flat object
  • Pencil or digicam (you'll see why in Part 3)
  • Small flat screwdriver or something similar to help remove needles (not needed, but may help)
  • Lots of Patience
  • This plastic tape from Walmart (less than $5)
Part A – Remove your gauge cluster
Note: This How-To is based on an '03 OZ.
  1. Remove two screws holding in black surrounding piece of gauge cluster. Pull out black surrounding piece.
  2. Remove three screws holding in gauge cluster. Two up top, one below in center.
  3. Pull out gauge cluster. The easiest way I've found is to pull it forward slightly then lay it's back down to face up. Then rotate to get it out.
  4. There are two sets of cables attached to the gauge cluster. Both are on the back of the cluster on the top with one on each side. There is a tab in the center of the connecter which you depress and then you can pull out the cables.
  5. Take your released gauge cluster inside.
Part B – Remove Needles
  1. Remove the clear plastic lens covering your gauges. This is done by pressing in the tabs that hold it in on the top and bottom.
  2. Remove the black surrounding plastic which separates your gauge faces. Again, there are tabs and top and bottom and one on each side. (Note: This step is optional, but makes it easier to take off the needles). Once the black piece is off, you have free access to the needles.
  3. Remove the little black needle stops on the Tach and Speedo. These pop out, so just bending them to one side will pop them out. You will notice the needles will drop lower.
  4. Now, by either taking a picture of the current needle position, or by lightly marking the needle position on the gauge face with a pencil, note where the needles are. This step is important to ensure that your gauges aren't off when you put your needles back on.
  5. For Tach and Speedo - Gently, firmly pull up on the needles. Pull up where the needle is mounted – the center of the gauge face. If you pull up on the far end of the needle, you can break it or sorse, bend the small shaft that holds the needle and then you'll need to replace your gauges - $278 at dealership. I've taken off my needles many times and have found that its easiest to pull on the needle side of the main plastic part with my left hand while prying/pulling up on the other side of the main (center) plastic part with a small flat head screwdriver. Once the needles are off, set aside.
  6. For Gas and Temp – These needles don't have little stoppers to hold the needles at the bottom gauge position. In order to accurately mark their current position, you need to pull the needles half way up. You will notice that once they are half way up, the needles will then rotate further down. This is the position you mark or take a picture of for replacement. After you mark the position, remove the needles the rest of the way.
Part C - Changing Needle Color
  1. Using an Exacto knife, or anything other sharp flat surface, carefully scrape off all the paint from the backside of the needle. Try to get as much off as you can. Wet sanding the back with 400 or 600 grit sandpaper will help remove any remaining paint. Turn over the needle often to see where you still need to remove paint. You will know you've removed it all when you turn the needle over (right side up) and it looks completely clear. Do this for all four needles.
  2. Now, take the color of tape you wish your gauges to be. I used the blue tape for blue needles. Using the white tape will make your needles white in the day, but will glow whatever your gauges glow at night. After you select your tape color, trim a piece of tape to cover the backside of the needle. This may take a couple of tries since you want to cut a piece basically the exact shape of the bottom side of the needle plus a little extra on both sides to wrap around. Basically you want the tape to cover enough of the back that when you turn the needle over, it looks like it was meant to be that color. You'll know when you got it right.
  3. After fixing the tape to all four needles, you are now ready to put them back on!
Part D – Put Everything Back Together
  1. Tach and Speedo - Now, place your needles back on and align with their original position (I lightly marked on the gauge face with a pencil the needles' position). I found that the easiest way to put them back to their original position was to push them on most of the way above the mark and then as I pushed the last bit of way left, rotate the needle to the mark. Be sure not to push the needle too far down and it will be pushing against the gauge face and won't be able to rotate freely.
  2. Fuel and Temp – As you did when you took them off, push them down to about half way. Rotate them to the mark you made of their position, line it up and then rotate them back so that the needle is pointing to about the center of the gauge and then push down the rest of the way. Be sure not to inadvertently rotate the needle while you push as you will change the needle position and your temp and/or fuel gauges may not read properly.
  3. After your needles are back on, gently do a mock sweep of the needles as if they were moving to make sure they aren't stuck on the gauge face. (Move the needle like you were revving your engine)
  4. Replace the black plastic surround piece for the gauge faces.
  5. Replace the clear plastic piece.
  6. Take the cluster back out to the car.
  7. Replace the two cables.
  8. Slide your gauges back into the car dash the opposite way you took it out.
  9. Replace the three screws which hold in the gauge cluster.
  10. Replace the black surrounding piece around the gauge cluster and replace the two screws to hold it in place.
Turn on your lights and admire your new needles!
Let me know if you have any questions about this How-To. I'll try to help as best as I can: lightrikz (at) gmail (dot) com
Mods you may want to sticky this since I've had a lot of requests for this. Also, is there a way you could add this to all the How To Forums so that the EVOs and Ralliarts can benefit from this as well, or can I do it?
Old Apr 9, 2005 | 12:55 AM
Here is a link to some pictures of my gauges with blue needles and the blue LED gauge cluster kit I sell to change the gauges blue.
Scroll down to post #27
https://www.evolutionm.net/forums/sh...d.php?t=124382
Old Apr 9, 2005 | 08:58 AM
wudbevo's Avatar
looks good!
Old Apr 10, 2005 | 01:29 AM
IceXpert's Avatar
i got the same brand stuff you bought, but the blue color looks darker on mine... are there different color shades, cause this green i have is kinda dark too..
Old Apr 10, 2005 | 08:59 AM
Are you talking about in the daylight? Cuz mine are darker in the daylight than what my picture shows. The flash makes it look lighter. Those are the only shades offered in that plastic tape.
Old Apr 10, 2005 | 05:59 PM
IceXpert's Avatar
ok. just thought there might have been different shades ,cause mine look darker and the roll order in the box is different, which could mean nothing..
Old Apr 22, 2005 | 11:35 PM
cupah20's Avatar
how did u get the lcd display blue? i changed my bulbs but still turned out red.
Old Apr 22, 2005 | 11:50 PM
Go to my website here: www.et.byu.edu/~zag/Lightrikz/docs.htm There is an installation instruction for the gauge cluster kit I sell. In it, I describe how to remove the orange film which sits behind the odometer.
Old Apr 23, 2005 | 12:15 AM
cupah20's Avatar
cool...thx!
Old May 19, 2005 | 11:45 PM
TeAmEmPeRoR's Avatar
crap, I knew that would prolly be the case. I figured that if I get yer bulb set on yer website and just change those, the lcd will still look red or orange. So I guess I will have to mess with the needles just to change that. Well.....if I gotta mess with the needles, I might as well change the color of them by following yer write up. Yer gauge cluster kit comes with the filter for the lcd right? or do we just take the filter off and leave it like dat?
Old May 20, 2005 | 07:37 AM
Yeah, by just removing the filter, the new bulb will then properly change the color. I'm actually going to start making these needle kits. I've finally gotten a hold of a set of needles.
Old May 20, 2005 | 09:43 PM
kewlness, but we would still have to install the needles ourselves right? So I mean, I'd rather suck it up and try it myself.....lol
I mean, it sounds pretty simple, just need patience and some ***** to do it right?...haha
Old May 20, 2005 | 10:09 PM
Yeah, its not that bad though. If you run into any problems, I'm here to help!
Old Jun 19, 2005 | 12:08 PM
mitsulancerrace's Avatar
Well i just tried it n didnt have anygood luck, i put BLUE tape on it n they look white. theres like scratches on the back of the needles, would i have to paint them blue, or is there a way to make it completely clear now?
Old Jun 19, 2005 | 08:10 PM
PM sent
