Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
help on flip flop trunk
Old Jul 23, 2005 | 10:30 PM
Honni414's Avatar
i seen wiscoshowoff02's car today in person and the flip flop trunk that he has that i was skeptical about looks a hell of a lot better in person.......it looks 1000 percent better....its hard to see the hinges and the custom trunk stops are a must otherwise your trunk will sit funny when its open
Old Feb 13, 2006 | 02:26 AM
CityKnight's Avatar
It only looks ghetto cuzza that silly bar hangin out with the rubber ends taped on, and you got the hinge bent.
You got the right idea tho.
I made mine as well the same way, even with the lock-latches, HOWEVER remove that silly bar and place rubber bushings on the trunk lids inside wall, so that when it closes itll hit the bar correctly, thats how you do it cleanly, OR another way is to apply a bar of angle iron straight across the lid about an inch over the hindges tips.
Then when it closes, the bar will "block" against the springy lifter parts on each side.
See here... No ugly rubber bar thing.
(...but there is an ugly butchered carpet thing ...Its been replaced.)
Old Feb 13, 2006 | 12:59 PM
WangMan's Avatar
That entire project is custom? Me likey
Old Feb 13, 2006 | 01:38 PM
TEJ's Avatar
TEJ
That is nice.
Old Feb 13, 2006 | 01:45 PM
forbidden color's Avatar
i don't see the function in that trunk...
it really doesn't look that good and it's not very functional either...
It WOULD be cool, if the trunk came out the opposite. Instead of going out and up, it'll come toward you and down.
now that would be something you could use. Use as a bench for when you're tired, eat off of it, etc.
lol
Old Feb 13, 2006 | 01:52 PM
Lancerguy'03's Avatar
hahah ^^ yeah i dot see functionality in that.....but what ever....what ever makes u happy????
Old Feb 13, 2006 | 04:16 PM
mitsuozboi's Avatar
Its basically a show mod. Your at a show and wanna show off your nice trunk set-up, why not have a custom trunk look rather then just it opening regular. score points with the judges.
thats my take on it.
Old Feb 13, 2006 | 04:31 PM
ThunderOZ's Avatar
+1 and its something that most cars dont have, sets it apart a bit
Old Feb 13, 2006 | 04:44 PM
Skylineracer's Avatar
From: Clifton New Jersey Lived: Daytona Beach, Florida Lived: Port Orange, Florida
CityKnight do u have better pics of what u did instead or can u point it out on your pics cause i think this is awsome. i have thought about it for a while since i saw it on ebay.
Old Feb 13, 2006 | 10:29 PM
CityKnight's Avatar
I wish I had doen a How-To...
Im gonna take some close up shots, and Ill post 'em, so you can see how I assembled it.
Gimme like 15...
Old Feb 14, 2006 | 07:20 PM
15 hours lol take your time
Old Feb 14, 2006 | 08:12 PM
05ES's Avatar
I had this for a white but got sick of my trunk not sitting totally aligned. so i took it out
Old Feb 15, 2006 | 12:35 AM
CityKnight's Avatar
Aright, here ya go... I should put this in the HOW-TO section, but I cant really explain how-to the way Id like to, so youll have to see, analyze, and mimick this time.
I dont remember what sizes I used either.
(Just use a tape measure, or estimate, its not difficult to figure out.)
Sorry I wasnt thinkin' and didnt take pics in the process.
I did use the locking nuts tho btw...
Place the lock in the right spot where the lid gives some space protruding. It will be a bit tilted inwards, so use some washers. Mark the spot where the lock will latch into with a Sharpie. I actually Painted the tip of the Latch and locked so it would make an exact spot on the bar. Do that.
As you'll see, you will have to bore the hole for the lock yourself. TIP: Dremmel !
Use a Rubber Bushing like that of a Skateboard Truck (Do-Do's) as the stopper, so it tilts just right, and straight w/ a cushion.
(Hmm... I should get a nice new White bushing, come to think of it.)
Some people bolt a bar of angle iron all the way across the thing, but I thought that was to bulky and ghetto lookin'. I prefer subtle.
At the Lid, you will have to drill holes for the bolts, in order for the hinges to line up in the proper place neatly. Also Important... There are washers inside the lid, on the bolt through the top hinges. Stick your fingers in the original big hole on the lid to hold 'em as you place the bolt in. I think there were 10 small washers on an individual bolt. This way itll be straight and wont bend the hinge like Wiscoshowoff02's (No offense in using yours as an example, I dont think you meant it to be sloppy looking as if youre careless, but you prolly just didnt think of this way. Its all good man ).
Old Feb 15, 2006 | 12:07 PM
Lunchb0x's Avatar
can i see an upright picture from the side, and how about a few of it when its closed to get an idea of alignment before i tackle this project again
Old Feb 15, 2006 | 12:20 PM
Turbopit's Avatar
I would take away points, not give points for something that looked "scabbed" on. It really shouldn't be to hard to make it look nice though.
