Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Radiator Flush
Old Aug 18, 2005 | 12:38 PM
blacklancerr's Avatar
Radiator Flush
I don't know if this is a tough thing to do or not, but I can't imagine it would be. Anyone done this before?? if so, how bout a little how-to???
Old Aug 18, 2005 | 12:59 PM
HobieKopek's Avatar
It's as easy as running a hose to your car, opening the radiator fill and the radiator drain.
Old Aug 18, 2005 | 01:05 PM
grubiaco's Avatar
It's as simple as hobie said. Just open the radiator fill when your car is cool and then go underneath the car (front right) and you'll see a little black knob on the radiator. Lossen the knob and drain the radiator. Don't forget to drain it into something. Also, you can drain the overfill tank by unclipping the hose and pulling that plastic bad boy out.
Old Aug 18, 2005 | 01:12 PM
N1te's Avatar
It's sooo easy. Just make sure to take the top cap off to allow airflow.
Old Aug 18, 2005 | 03:10 PM
cool. thanks guys. that's what i thought, just wanted to make sure.
Old Aug 18, 2005 | 03:48 PM
HobieKopek's Avatar
Have fun. Oh, and if you use green (environmentally friendly, not the color itself) anti-freeze, don't worry too mucha bout a little spillage. Just try to keep it off your driveway/garage floor, because coolant sucks to clean up.
Old Aug 18, 2005 | 06:35 PM
Slovak's Avatar
That does not really completely flush the system, just what is in the radiator, there is always some left over in the block.
Old Aug 18, 2005 | 11:16 PM
N1te's Avatar
so if you really want to flush everything, fill the radiator up with water after u empty it, run the engine (idle) for a couple minutes, then turn it off and empty again. Refill with 50/50 mix and you're completely flushed of all bad things.
Old Aug 19, 2005 | 05:12 AM
Slovak's Avatar
+1
Old Aug 19, 2005 | 10:32 AM
HobieKopek's Avatar
I kind of assumed he knew to run the car when he filled it with water. After the simple posts he said "that's what I thought".
Old Aug 19, 2005 | 01:11 PM
grubiaco's Avatar
True dat.
Old Aug 19, 2005 | 04:38 PM
i did know that. thanks though.
Old Aug 19, 2005 | 05:01 PM
grubiaco's Avatar
What else you doing with you car. If you ever need help working on your car give me a holla.
Old Aug 20, 2005 | 10:06 AM
i need an oil change and a tranny fluid change. just gonna pay to get that done though cuz i heard the tranny part is a pain.
Old Aug 20, 2005 | 10:20 AM
HobieKopek's Avatar
I think it's the tranny flush that's difficult. I haven't done that yet though, so I couldn't comment.
