Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
How to remove dome light
Old Oct 10, 2005 | 12:06 PM
initialDRacer's Avatar
Is there a way to remove the dome light without damaging the plastic cover? I can't seem to find a way without breaking the plastic. How do you remove it? Any help would be great. For anyone who doesn't know, it's the light on the roof. Thanks.
Old Oct 10, 2005 | 12:21 PM
Evoryder's Avatar
u have to cut the clear coat from around hte edges
Old Oct 10, 2005 | 04:10 PM
What do you mean? The light is not even painted. Are you talking about the plastic cover? I just need to change my light because mine won't turn on anymore. I bought replacement bulbs at autozone.
Old Oct 10, 2005 | 04:21 PM
blacklancerr's Avatar
^ignore him
all you have to do is use a small flat head screwdriver and pry it off. i think its the back that you can slide the screwdriver in. you should see a few little notches, and just pop it out.
Old Oct 10, 2005 | 04:24 PM
So that wouldn't break the plastic or anything? Man, you don't realize how cheap the lancer parts are until you do surgery
Old Oct 10, 2005 | 04:26 PM
i've taken mine off a few times. just don't try to muscle it too much and it'll be fine. it can take a little pressure on it
Old Oct 10, 2005 | 04:29 PM
alright thanks bro. I'll try that right now
Old Oct 10, 2005 | 04:37 PM
no prob. let me know if you have any problems
Old Oct 13, 2005 | 10:21 AM
Evoryder's Avatar
just cut it.
Old Oct 13, 2005 | 10:25 AM
timdog4life's Avatar
the clear plastic piece pops right out, if you want to remove the entire assembly theres a screw or two holding it up. I had to remove mine to get the headliner out when I dye'd it black.
Old Oct 13, 2005 | 11:50 AM
just cut it.
the hell are you talking about??
Old Oct 13, 2005 | 12:01 PM
Evoryder's Avatar
dunno...
...if in doubt...cut it out.
Old Oct 21, 2005 | 06:09 AM
CityKnight's Avatar
You should be able to gently pry at it with a small flathead, no?
Old Nov 16, 2005 | 02:56 PM
ThunderOZ's Avatar
are there like any kinds of colored tape of sumthin that can be put over the actual bulb?
Old Nov 16, 2005 | 03:37 PM
i would just buy a new bulb. they're cheap and all you have to do is plug it in.
