Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
HUGE PROBLEM w/ GROUND WIRE KIT!
Old Feb 21, 2006 | 12:09 AM
  #31
CityKnight's Avatar
Well yeah and no, I had the Torinos, and figured I really wanted that money so I said F-it and took 'em back.
Yes I got the generics and saved 600 dollars. Honestly tho, I really like 'em!
These are also made o' Memory Foam, they really dont feel that much different. Their comfy and hold ya in nicely, but they are heavier.
Originally Posted by ambystom01
I meant why is the filter section in the middle of the pipe.
Thats a Bypass Valve.
Old Feb 21, 2006 | 11:35 AM
  #32
ambystom01's Avatar
There's just nothing you can say to that.
Old Feb 22, 2006 | 08:21 AM
  #33
eehjay's Avatar
Hahaha, wow.
I was going to do a grounding kit this upcoming weekend and was just reading up on some stuff. Thanks for solving CityKnights probs. I think he was just trying to make the most out it and ground as much as possible, right? Question though, do these grounding kits help with those static shocks that everyone seems to keep getting in their lancer?
Old Feb 22, 2006 | 08:28 AM
  #34
Street Solutions Racing's Avatar
alt
Ck The Alternator, Its Probably Overcharging The Battery. I Work At A Honda Dealership, And When Alternators Go Bad....they Overcharge. Ck Your Grounds!!!!
Old Feb 22, 2006 | 09:02 AM
  #35
Kurt's Avatar
I have a question. I am looking at a ground wire kit and on the directions it says to run one of the grounds to the headlights. Does anyone that has a grounding kit have it hooked up that way?
Old Feb 22, 2006 | 10:57 PM
  #36
CityKnight's Avatar
Originally Posted by eehjay
Hahaha, wow.
Well yeah, but more-so I was just trying to follow the directions, and not be short 2 locations.
About the electrostatic shock... We wish!
Old Feb 22, 2006 | 10:59 PM
  #37
CityKnight's Avatar
I havent seen that done yet, however people say that when you install a Ground Kit, that the Headlights brighten up.
I dont even remember anymore if they have or not, to tell ya the truth...
Old Feb 27, 2006 | 12:52 PM
  #38
Tainted Winter's Avatar
Hahaha, wow.
Believe it our not... this static shock is not cause by the electrical system. As you drive you car the air flows over and around it (DUH) and dependind on how dirty your car outside is the air causes friction. This is what causes the spark. The entire car acts as a capacitor untill it is discarged. Wierd, I know, but there is really not alot of harm.
Source: Super Street, Had a product that grounds the outside and stores the charge in a capacitor-like canister giving you extra HP (Better ground, better spark principle)
Hope this sheads some light...
Old Feb 28, 2006 | 12:19 PM
  #39
eehjay's Avatar
Ah, okay. Makes sense, kinda like when you start rubbing your feet on carpet and touching people.
Old Mar 8, 2006 | 03:44 PM
  #40
kott_tot's Avatar
when i put my grounding it on i had no idea if my lights were brighter, but my friend that i sometimes drive to places with looked in his rearview mirror and thought my highs were on, so i guess it did work
Old Mar 9, 2006 | 04:48 PM
  #41
sykou's Avatar
Was digging through the cobwebs and found this from waaayyy back. THE BIG 3!!
1) Wire from neg battery terminal to chassis
2) Wire from Engine block to chassis
3) Wire with fuse from Positive battery terminal to alternator
According to number 3 the alternator is positive. So logically connecting it to a negative would obviously cause a short. I think thats the problem...
NoReason
Jun 7, 2015 07:05 AM
Evo8zip
Jan 16, 2008 01:38 PM
BARNSEY
May 31, 2007 12:18 AM
EvoIXMR
Jul 30, 2006 07:53 PM
Walkingchaos
Jan 4, 2006 09:21 AM
