Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Ho-To-Program Keyless Remote From Ebay
Old Mar 22, 2007 | 03:56 PM
Walkingchaos's Avatar
if its an ES with no remotes from the dealer it probably doesnt have a remote setup in it to program.
Old Mar 22, 2007 | 04:01 PM
OhSixLancer's Avatar
I got it used so I don't know if it ever had the option. Is there a way of checking? Also, how far up does the "jumper" need to be? I got the paper clip shoved all the way up there and that didn't work
Old Jun 4, 2007 | 03:34 PM
voidmind's Avatar
Wow that worked too easy. Dealers are a ripoff....
Old Jun 25, 2007 | 04:06 PM
jeffreyinigo's Avatar
i did this but my remote doesnt work for some reason i guess. the doors locked and unlocked when i pressed the hazard button 6 times then did the remote part of it and it didnt work. what can be wron with my remote? does anybody have a picture of the inside of the remote? i just changed the battery also
Old Aug 18, 2007 | 05:28 PM
zoo_yorker687's Avatar
Took my like 30 seconds with a paper clip by myself! Make sure its not a vinyl one though.
Old Sep 26, 2007 | 12:36 PM
OEMspecs's Avatar
very easy.. thanks i got2 progm it right away!
Old Nov 8, 2007 | 08:20 AM
sXericerider's Avatar
Muhahahaha it works
Old Feb 27, 2008 | 02:15 PM
RDSSPIEGEL's Avatar
So do you need the FCC ID CODE
FcC id code or is that just BS, I called my dealership and said they had to program it and so on because the code on the remote always changes and so on its never the same... I posted on the FCC but no answer until i found this .....I am waiting to buy a remote on ebay but hesitant about the Fcc id on it... would it matter...?
Old Feb 27, 2008 | 06:55 PM
autobahn3000's Avatar
the fcc on the back of your original keys has to match the new remote. Make sure u follow the instructions carefully from www.programyourremote.com (the first Post). and also remember that your doors must be shut before connecting the 1 and 4. I used a 2 paper clips and a wire with 2 alligator clips. so u plug in the two paper clips and get in your car and put the keys in the ignition and then connect the two together and follow the rest of the instructions. It works great and only took a couple minutes!!! Paid 8 dollars on ebay for remote and had a key made at walmart for 1.37. yes walmart makes double sided keys!!!!!!
Old Feb 27, 2008 | 11:16 PM
RDSSPIEGEL's Avatar
Thats my problem i lost the remote and I dont know tha numbers besides i think they where worn out.... so could i just use/buy any?
Old Feb 27, 2008 | 11:21 PM
Wicked E's Avatar
Wonder if this procedure also works for the JDM Evo key...
Old Feb 28, 2008 | 03:59 PM
most likely your remote had these numbers: Lancer- Back of Remote
FCC ID: OUCG8D-525M-A
CANADA: 850104241A
OMRON G8D-525M-A
Old Oct 18, 2008 | 08:25 PM
Ketchup2me's Avatar
I found a remote at the junkyard. It was for an eclipse it works on my lancer now, just a tip if anyone is looking for cheap/free remotes... junkyards!!!
Old Sep 16, 2009 | 08:37 AM
Jimbowned's Avatar
When has Walmart NOT done any service imaginable?
Old Sep 16, 2009 | 04:15 PM
g2bsuperwoman's Avatar
wow so easy
thanks alot
