Repainting Rear Drum Disk
I want to do it this weekend, but they look rusted from when i had the stock wheels on there, but was painted a silver color..since i changed wheels it dont cover the whole drum as stock used to so i want to repaint it black and possibly send down the rust if possible....can someone tell me if sand paper to rust is the best way to go, and what type of sand paper should be used...wet/dry/grit...
I used a fine wire brush to scrape of the rust, then I sanded the drum down. Then I used the wire brush again to get the spots I missed, washed it down with some soap and water, then used sand paper to make it smooth again. I took High Temperature Paint and sprayed the drums, waited 30 mins and gave it a second coat. It looks nice, I have some pics if you wanna see.
Buy this stuff called Naval Jelly. Its a rust dissolver. Use a wire brush to get all the big rust flakes off then put a coat of the naval jelly on. LKeave it for ten minutes and repeat untill the majority of the rust is gone. Then go over it with sandpaper. I used VHT Brake And Caliper Paint. Its a satin black so it looks really stock. Figure its made for brakes so it must last longer than using the engine one...
i took my drum cover off.
probably a good job too, if i hadnt i wouldnt have found my brake fluid leak. lol
Im gonna do my front brakes next also. im just gonna get one of those $15 paint kits to do it though. Save some hassel.
it seems it would be easier to paint with it off. it was easy for me.
all you need is a hammer.
jack up the car, remove the wheel. then go press the brake a few times, pump the hand brake a bit, (this will release brake pressure) then give the drum a few wacks from side to side with the hammer, and it will come right off.
then just sand and paint.
