Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Help With Manual Boost Controller
Old Oct 8, 2006 | 09:47 AM
sawgunner249's Avatar
i NEED HELP...........................how do i install boost controller pics would help to
Old Oct 8, 2006 | 10:58 AM
Blacksheepdj's Avatar
Originally Posted by Wikipedia
A manual boost controller is a simple mechanical and pneumatic control to allow some pressure from the wastegate actuator to escape or bleed out to the atmosphere or back into the intake system. This can be as simple as a T-fitting on the boost control line near the actuator with a small bleeder screw. The screw can be turned out to varying degrees to allow air to bleed out of the system, relieving pressure on the wastegate actuator, thus increasing boost levels. These devices are popular due to their negligible cost compared to other devices that may offer the same power increase.
Generally a manual boost controller will not be accessible from inside the car, though some are designed to be. An installation that allows access from inside the car (as opposed from inside the engine compartment) is more complex, as the tubing must be longer and a hole must be drilled. It is possible and beneficial to use two manual boost controllers at different settings with a solenoid to switch between them for two different boost pressure settings. Some factory turbocharged cars have a switch to regulate boost pressure, such as a setting designed for fuel economy and a setting for performance.
OK, if you have a turbo kit, I assume you know what's what...
I assume you'd know what the boost control line is, so just put it in there...
Old Nov 18, 2006 | 01:09 AM
eponti's Avatar
go to LANCERSHOP.com they have an article on how to install mbc
