Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
coolant bypass mod
Old Jun 14, 2010 | 12:31 AM
  #31
romanian's Avatar
Did it today. Not a great deal hapened, it does warm up a tiny bit harder, but when it warms up the idle droped and the engine idles smoother.
Old Jun 14, 2010 | 07:16 AM
  #32
EvolutionESX's Avatar
Ya same here, not much happened.
Old Oct 18, 2010 | 02:22 PM
  #33
jwick76's Avatar
SO here's my question, what are you guys noticing for difference in idle rpm? Anything significant?
Old Oct 19, 2010 | 01:34 PM
  #34
davidmitsusrock's Avatar
I think I'll pass on doing this. Seems like too much trouble for no real gains.
Old Oct 19, 2010 | 01:57 PM
  #35
jwick76's Avatar
Actually, the hp gains aren't what I'm interested in. This sounds like it's going to fix my rough idle, which is why I was asking for differences in idle rpm. I'm idling at 170+degrees at 500-600rpm, when cold 700-1000rpm. At the higher idle, with my semi- solid motor mounts (RRM), i idle smooth...when it drops at warmup, I start idling rough...
I'm going to do this mod as soon as my thermostat comes in (getting a 180degree one) and I do a coolant change. I'll post the differences.
Old Oct 23, 2010 | 08:23 AM
  #36
jwick76's Avatar
ok, got the new thermostat in, did a coolant change with water wetter, and disconnected the TB coolant lines. NO change with idle RPM at all:-( total disappointment. TB heats up exactly the same (haven't taken any infrared measurements) based on idle performance at 160+ degrees> I did, however, notice a little bit more responsiveness at hitting the accelerator approaching WOT. *shrugs* not enough to blow me away, but enough to notice.
Still irritated this did nothing to my idle RPM. I'll be adjusting the TB next.
Old Nov 8, 2010 | 12:17 PM
  #37
jwick76's Avatar
Quick question, has anyone noticed pulsating idle after this mod? Specifically when decelerating to a stop, and for about 30 seconds or so. Noticing about a 250rpm fluctuation. Nothing horrible, just annoying. Wondering if the ISCV is working overtime and having issues...
Old Nov 8, 2010 | 05:11 PM
  #38
zulu989's Avatar
doing this while being turboed has caused some problems with me, iac valve code pops up and it continues to rev when u release the throttle after boosting! i changed it back and it doesnt do it anymore : )
9!'clipseDOHC
Jan 9, 2016 10:21 PM
R4a2m0o
Dec 15, 2011 05:18 AM
EVO8emUp
Feb 7, 2010 10:23 PM
GTVEVO
78
Dec 24, 2005 08:36 AM
