Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
Yellow Fogs
Old Oct 24, 2007 | 04:48 PM
08 lancer De's Avatar
Yellow Fogs
does any one know if they have yellow fogs for the 08 lancer yet all comments welcome
Old Oct 24, 2007 | 04:49 PM
bumps
Old Oct 24, 2007 | 05:09 PM
cspec's Avatar
H11, is the bulb code, you can buy yellow ones from anyone. i recommend piaa.. anyways, there you go, or you can overlay film.
Old Oct 24, 2007 | 05:11 PM
SpeedI2acerX's Avatar
yellow tints on ebay
Old Oct 24, 2007 | 06:22 PM
08LancerEVO's Avatar
DONT GET THEM OF EBAY! you will be surely riped off, im getting these for my car fo sho (headlights and fogs) check here
http://www.headlightarmor.com/index....nfID=34&Page=1 (scroll to the bottom)
Old Oct 24, 2007 | 06:45 PM
melv_VIII's Avatar
yup u can get HID for your fog..i got mine....H11 3000k for my fog light...
Old Oct 24, 2007 | 06:48 PM
evo_soul's Avatar
Get the Nokya Yellow Bulbs Vs. PIAA IONs or Applying a yellow film
Nokyas run for as cheap as 22 dollars at big box stores. And they perform well.
I have been running yellows for my headlights and fogs for 5 years now in 3 different cars, so I know their plus's and draw backs. I have also tried PIAAs other bulbs and know them as well.
Nokyas are bright, and generally fail or burn out at the 1.5 year mark. Which at the point doesnt matter because the yellow filter on the bulbs tends to fade at that same 1.5 point turning about 30% whiter, losing its yellow dominance.
Vs. Nokya, my experience with the IONs is they look about the same (a bit brighter due to the gas and technology they employ. But the major downside is the cost. The cost can be upto 3X. The other downside is failure rate. Now i cant talk about the ION bulbs but I have use the Purples GTX that PIAA had a while back. I have had a bulb blow out 3 times within the 1 year period, on two different cars. so thats 6 sets? unsure why,. My working theory is that due to the way they have patented their bulbs to work with lower wattage, I think the bulbs are suseptible to failure under unstable voltage levels. Meaning if you are running a sub / amp audio system and do not employ a capacitor, then you are giving your headlights terrible surges that speed up the blow out death of the bulb.
After comparing my situation with others in my other car club thats the only thoery that works. All that aside.
I select Nokyas over other bulbs just cause of the fact that I have used them for a while, there are other bulbs are better, no doubt, MTEC, PIAA, and so on, but these ones give good light, they are cheap, and reliable.
Just make sure you get them from an authorized dealer, their are alot of fakes out there.
My two cents
Old Oct 24, 2007 | 08:16 PM
rav's Avatar
rav
i'll try to find a better camera when it stops raining outside and without the fence
Low beams are MTEC cosmic white 5750k
Fogs are Nokya hyper yellow (cheap around $20)
Old Oct 24, 2007 | 08:36 PM
mines hotter's Avatar
i have the luminics jdm yellow fog light bulbs and there not bad they are pretty bright n they were only like 40 buks
Old Oct 25, 2007 | 08:42 PM
all right thanks guys
Old Oct 25, 2007 | 08:52 PM
wow both ur cars mad f ing hot
Old Oct 25, 2007 | 08:59 PM
so the gts doesnt come wit yellow fogs at all then
Old Oct 25, 2007 | 09:08 PM
nope i wish they did lol
Old Oct 26, 2007 | 01:13 PM
damn
Old Oct 27, 2007 | 04:03 PM
Eagles GTS's Avatar
anyone know what bulb number or brand for some bluish tint fogs
